587,916 active members*
3,949 visitors online*
Results 1 to 9 of 9
    Nov 2011
    26
    PCNC 440 Failure
    The VFD went out of my 3 month old 440..
    Just added a tool to the ATC and when it loaded and started the op the Spindle didn’t start. After troubleshooting found an error code on the VFD. TORMACH Overnighting a new one on Monday.
    Jun 2016
    184
    Re: PCNC 440 Failure
    Yup... Happened to me to without ATC. Lets hope it does not happened again, its not cheap part to replace if I have to pay for it.
    Aug 2011
    61
    Same exact thing happened to me two times. The controller went dead when I added the pbd and atc Its pretty bad when adding stuff and the controller burns out but good to know im not the only one this happens to. Im kinda worried about adding the 4th axis when it comes out now that my machine is no longer under warranty.
    Jun 2016
    184
    Quote Originally Posted by nutzilla View Post
    So your spindle DC controller was replaced twice? I hope that's not the case since that means they are totally unreliable item. Tormach should really be extending warranty on the electronics on these machines since they are most common thing that fails and which should really not fail in just couple of months worth of use.
    Aug 2011
    61
    Quote Originally Posted by coffeetek View Post
    Oops my mistake not the spindle controller (vfd). But the controller that controls xyz.
    Jul 2004
    1424
    That Leadshine MX3660 definitely isn't ready for prime time. Tormach must be sorry they went for the all-in-one solution instead of the tried-and-true machine control board and separate drivers.
    But it probably makes the electronics panel build much faster.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Nov 2011
    26
    Install on the new VFD was simple. Everything works fine. Only quirk is that the VFD light on the status page does not illuminate at Spindle speeds less than 1250 rpm. Anyone else see this??
    Sep 2009
    1856
    Why did they not go with US made controller
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    May 2016
    138
    I'd assume cost.
  1. VFD failure
    By dbunyip in forum Tormach Personal CNC Mill
    Last Post: 12-19-2017, 09:26 PM
  2. How to reconfigure Pathpilot from PCNC 440 to PCNC 770?
    By MetalDawg in forum Tormach PathPilot™
    Last Post: 03-03-2017, 02:23 AM
  3. PCNC 1100 vs PCNC 770 (Is the 1100 worth it)
    By thunderdork in forum Tormach Personal CNC Mill
    Last Post: 09-21-2016, 08:43 PM
  4. Checking Amp for failure
    By bobio in forum Fadal
    Last Post: 09-14-2011, 05:38 PM
  5. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
