588,058 active members*
5,214 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > New Encoder - New Cover - Ideas ???
    Oct 2008
    2104
    I need to replace a cover that looks like this...
    http://www.yumabassman.com/encoderco...er%20Cover.jpg
    ... with a cover more like this ...
    http://www.yumabassman.com/encodercover/New%20Cover.jpg
    , because the new encoder takes up more room.
    I could make it out of fiberglass (messy), cut it out of a solid block of acetal or aluminum (expensive), or fold a hack job out of sheet (sharp edges and not pretty), but I am hoping somebody will suggest a simpler more elegant solution.
    Here is the application:
    http://www.yumabassman.com/encoderco...-47-39_861.jpg
    I would like to funnel any coolant away from it, and protect it from being bumped into there on the front of the machine.
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2104
    I may try vacuum forming with a clear acrylic. It will look cool if it works, and its something I have never done before. I've got everything to do it except some Plexiglas thin enough to vacuum form.
    Bob La Londe
  1. Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder
    By TNBG_LTD in forum Want To Buy...Need help!
    Last Post: 03-18-2020, 08:54 PM
  2. VF2 Z way Cover
    By Mic6 in forum Haas Mills
    Last Post: 07-10-2008, 08:18 AM
  3. Mill Cover
    By Clot in forum Benchtop Machines
    Last Post: 03-25-2008, 01:01 AM
  4. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
