587,997 active members*
1,891 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 24V from SMPS power supply ...
    Jun 2010
    40
    Hi ,
    Iam trying to build a DIY CNC router.
    Iam using stepper motors, whose drivers need 24V power supply & controller needs 5V supply.
    Iam wondering whether I can connect 2 SMPS supply from standard PC in series and get my 24V for the stepper drivers.
    PC powersupplies are very cheap, and give enough amps needed for steppers, but give only 5V & 12V.
    Looks like the COM of SMPS voltage is connected to the chasis.
    Iam thinking of isolating the COM from the SMPS chasis and using 2 SMPS in series.
    Have any one tried this?
    regards
    Nov 2010
    PC power supplies.
    The quick answer is yes, the following link will tell you how.
    ProCooling.com
    I have tried it and very satisfied.
    Trevor
    Jun 2010
    40
    why resisitor across 5V?
    Any idea why resistors are to be connected across the 5V? ( as suggested in the procooling site)
    I was planning to use the 5V to power my controllers. So dont understand why he has suggested to connect lowOhmHighWatt resistors across the 5V.
    regards
    Jan 2010
    2141
    This is just a guess, but apparently some PC power supplies will not produce any output unless they sense a sufficient load current on the 5 volt rail.
    So the resistors may be providing such a load to ensure that the power supplies function properly.
    Nov 2010
    Load resistor
    Switch mode power supply's normally need a load to work, as PC power supply's normally supply 10s of amps so the little current used by your driver boards would not be enough to kick start the power supply.
    You can still use the 5v supply.
    The following link may help as a resistor is built in and it shows the other lines are good.
    PC Power Supply Tester 20/24 Pin PSU ATX SATA HDD on eBay (end time 09-Feb-11 07:44:37 GMT)
    Or do a search on Ebay for "PC power tester"
    they are so cheap from Hong Kong it is worth having.
    Trev
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. controller power supply 115/230v OK for Australian power?
    By Momill in forum Australia, New Zealand Club House
    Last Post: 07-07-2011, 05:06 PM
  3. SMPS power supply ...
    By CNCpatriot in forum DIY CNC Router Table Machines
    Last Post: 01-18-2011, 02:29 PM
  4. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
