TM6 vs TM8 Selection Help wanted.
I will be making parts primarily for my own business.
At least 12 different parts all in small lots, typically 10 to 50 parts per batch.
The highest volume part is 1.5" Delrin/Acetal, the typical parts range from 5/8" diameter Stainless to 2.0" 4130, low volume parts are 4.5" 4130 and 6.5" diameter 6061. Most parts will involve face, profile and bore some with ID/OD threading see list at end of this post
I'm coming from a background of low HP manual lathes with an 1800 RPM maximum, so I don't have any experience with CNC lathes. I do have some g-code experience with a low HP CNC mill.
I originally priced up the Haas TL-1 and TL-2 and talked with a few folks who have them. My conclusion was that by the time I had configured up the Haas machines in a ready to work configuration, I could buy a Hurco Slant Bed TM6 for basically the same money. The TM8 is $10,000 more.
I have studied the specs for the TM6 and TM8.
The significant differences to me are:
TM6 6" chuck, 1.75" bar capacity, 6000RPM, 3/4" tooling, 12 tool turret
TM6 8" chuck, 2" bar capacity, 4500RPM, 1" tooling, 10 tool turret
TM6 fits the budget better
TM8 chuck would handle the larger but low volume stock easier.
How important is the extra RPM range of the TM6?
Or will I regret being limited to 4500 RPM on the TM8 for the smaller parts.
How well will I be able to chuck a 6.5" piece of raw 6061 on the 6" chuck?
Should I budget for a Quick Change chuck jaw (or Chuck) system?
How repeatable (TIR) is swapping soft jaws on a power chuck? (I would like to avoid a re-bore of soft jaws on every setup.
How repeatable (TIR) is swapping the power collet closer for the power Chuck ?
List of materials and raw stock length.
Highest Volume parts (batches of 40 to 100)
1.25", 1.5" and 1.75" Delrin/Acetal profile and bore less than 2" length
Medium Volume Parts (batches of 10 to 25)
5/8" and 3/4" diameter SS 303 less than 2" in length
1" diameter 4140 ID and OD threads
1.25" 1040 ID threads 1.4" deep
1.5" 4130 less than 4" length (precisely parted tubing)
2" 4130 5" long 5/8 OD threads, profile from 5/8 to 1.9"
2" 1040 5" long 5/8 OD threads, profile from 5/8 to 1.9"
Low volume parts: (batches of 4 to 8 parts per batch)
4.5" 4130 2" long
6.5" 6061 4" long, Deep 1." diameter bore, (initial profiling will quickly reduce one end to 5" and the other to3.5", could rough down on end on mill prior to chucking)
/Frank
