I'm having trouble getting SC9 to correctly machine out an inner lip inside of a cylinder. No matter what I do I can't get SC9 to machine the curve under the lip correctly (above the lip was done with a "Finishing Morph" and a basic endmill). Here's the IronCAD side profile drawing below to understand the shape:
Don't be deceived by the 2nd image. Here I tried "5D Contouring" with "Contact Tool Type" defined as "Fixed". I then defined the top and bottom paths but SC9 ignored the surface of the lip and cuts straight through until it gets to the bottom level. Leaving my piece lipless. Sniff.
I bought a double angle (60°) chamfer mill specifically for the operation to allow me to get under the lip, which has a depth of <0.1". With the help of Tormach's SprutCAM tech support, Jason, I figured out how to add the tool to the library (initially I had followed Eric's video on creating custom tool shape but ran into other issues quickly afterwards). Here is the tool parameters screen for the double angle chamfer mill:
TIP for Newbies Like Me:
There was a trick to even get this "two angle tool" type to show up. In SC9 the shaped tool option doesn't even a appear for some common tool operation types like 2D Contouring, Waterline or Finishing Morph. The Shaped Tool type (and then the type "Two Angle Tool") does appear with operation types like 3D contouring, 5D Contouring, and "Make Shape Cutter".
Any suggestions on how to attack machining the curve under the lip of the inside of this cylinder in SC9/PCNC1100?
I'm open to buying a different tool just not a different CNC or CAM software package.
Thanks in advance for any suggestions!
Sascha
Tormach PCNC1100, PathPilot v.1.9, SprutCAM 9
