588,199 active members*
5,026 visitors online*
    Sep 2005
    114
    4 axis foam machine
    I am wanting to build a 4axis foam hotwire cutter. if I get the hobbycnc foam pro package, what else do I need other than software and the machine.
    I do have a 50vdc powersupply is that to much or does it just draw as much power as it needs?
    Jan 2007
    219
    The hobby cnc pro board can only handle 42V. If you go over this you will fry it. -Adam
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    Sep 2005
    114
    Is a powersupply all i need with that package, and does it just plug into the computer without going thru a breakout board.
  1. Needs Help... building CNC foam Cutting Machine
    By javagreen in forum CNC Wire Foam Cutter Machines
    Last Post: 09-27-2008, 06:39 PM
  2. Needs Help... building CNC foam Cutting Machine
    By javagreen in forum Stepper Motors / Drives
    Last Post: 09-19-2008, 02:45 PM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  4. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  5. RFQ: Machine a prototype part - perhaps out of foam?
    By joemartins in forum Employment Opportunity
    Last Post: 10-08-2005, 07:16 PM
