588,216 active members*
3,949 visitors online*
    Sep 2007
    92
    TOOLBAR ISSUES
    I am using X2 MR2 for now. I modify my toolbar the way I like it, I went to SETTINGS-CONFIG and set the default location to look for it at startup but for some reason it changes back to a previous arrangement all by itself?? any help would be greatly appreciated
    Sep 2007
    126
    Toolbar States
    This is where & how I save my setting's :Setting's\Customize\ then click Toolbar States & set it up there & save it as default.
    Harold C.
    Mar 2006
    1013
    Besides making a new toolbar and saving it, you have to tell Mastercam to make that your Default toolbar. You should also make a new configuration (with the name of your choice) and make that the default configuration at start up.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Apr 2009
    Do you have administrator rights on your pc? I had similar problems with my setup. I found that it'll only save any changes I make if I'm logged on as an administrator.
    Dec 2008
    3137
    Quote Originally Posted by CNC_BOB View Post
    The System config is only a small part of modifying toolbars
    In t/bar area, right click a grey area, you can select the toolbar state you want.
    with this customise area open, you can also modify the actual t/bars,
    but they will also have to be saved in the " CUSTOMISE" dialog screen for the mods to stick.
  1. Gray toolbar ???
    By MachineManiac in forum CamWorks
    Last Post: 04-28-2012, 02:08 PM
  2. AutoCAD 2000 missing layers toolbar
    By skippy in forum Autodesk
    Last Post: 09-16-2008, 09:03 PM
  3. Plot toolbar and user interface
    By single phase in forum NCPlot G-Code editor / backplotter
    Last Post: 10-11-2006, 08:39 PM
  4. How are you liking the CNCzone Toolbar?
    By cncadmin in forum Community Club House
    Last Post: 07-05-2005, 07:54 PM
