588,555 active members*
4,692 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Lets talk feed rates (milling)
    Feb 2005
    753
    Okay. I am trying to program haas mill. I am used to lathe feed rates of .015" inches per revolution.
    How do the mills work?
    Dec 2008
    3142
    Lathes , generally are programmed in feed units per Rev = G95
    this allows you to control the RPM and still maintain the programmed feedrate
    Mills on the other hand, can swing both ways (pun), normal progamming is with G94 ( feed units per minute ), this allows feedrate and RPM control to be independant to each other.
    setting up a milling program involves many factors, width and depth of cut, # of flutes, work holding, cutter stickout just to name a couple . To fine tune the program separate control of the feed and speed is required
    using G95 on a mill is best highlighted when tapping, the programmed feedrate need not be altered if the RPM needs adjustments, just remember to switch back to G94 when finished tapping, or the machine will seem like rapiding all thru the next tool operation.
    Downside of using G95 on a mill, if RPM = zero, the machine no move boss
  1. Lets talk about BRUTE machines....WOW
    By carbidecraters in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2010, 08:23 PM
  2. Feed rates
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 11-26-2008, 03:35 PM
  3. Feed rates?
    By Rainman229 in forum G-Code Programing
    Last Post: 02-23-2007, 06:47 PM
  4. Lets talk financing
    By carbidecraters in forum MetalWork Discussion
    Last Post: 04-18-2006, 08:00 AM
  5. Rpm and Feed Rates
    By Xeno in forum Uncategorised CAM Discussion
    Last Post: 02-23-2004, 11:06 PM
