how do I control rapid % in my program without touching the 50% key? ( i need rapid movements to slow from 100% to 50% at the end of the prog) is there an M code I am not seeing somewhere that will allow me to do this?
I don't think you can do that.
Just replace the G00's with G01's and use whatever feedrate you want.
I am pretty sure you cannot do that.
IOf you have an older machine you may find using G01 with a rapid feedrate is too slow but on newer machines the maximum feedrate is often the same as the rapid, or at least a 50% rapid.
