588,506 active members*
5,542 visitors online*
Results 1 to 9 of 9
    Jun 2005
    180
    Visual Basic Express
    Does anyone know anything about Visual Basic Express, and it's limitations vs. the standard Visual Basic?
    Mar 2004
    261
    VB Express is dotNet. dotNet is a real departure from the way programs and language use to be used. These languages are compiled to a EXE is desired or can be used as script in an ASP web application.
    If you want to play with dotNet for free try Sharp Develop at:
    http://www.icsharpcode.net/OpenSource/SD/
    RipperSoftware
    Apr 2005
    3634
    Who Should Use Visual Basic Express?
    Visual Basic Express Edition is a powerful tool capable of creating fully functional applications and components that can be shared with others. It is not, however, intended for professional developers or for programmers that work in a team environment. Other versions of Visual Basic provide features that meet the advanced needs of professional and team development.
    If you need to write applications that connect to a networked database, interact with Microsoft Office, support mobile devices or 64-bit operating systems, or require remote debugging, you will need a more advanced version of Visual Basic.
    http://msdn2.microsoft.com/en-us/lib...fb(VS.80).aspx
    I think that last line is your answer.
    Jun 2005
    180
    What I would like to do is to make programs that I have written using VB, now running in Excel into stand-alone executables. It looks like VBExpress can do that. Right?
    Apr 2005
    3634
    Quote Originally Posted by rweatherly View Post
    I guess?
    http://forums.microsoft.com/MSDN/Sho...95540&SiteID=1
    Apr 2005
    3634
    This forum might have better answers for you.
    http://forums.microsoft.com/MSDN/Sho...D=159&SiteID=1
    You may need to do a lot of rewriting because the Excel VBA functions you're using may be a bit different from the VB functions. Also, you're probably relying on some Excel functionality that you'll possibly need to re-create, or go about a different way. But, it should be doable.
    Jun 2005
    180
    Thanks. Most of the code is really plain old BASIC, with few Excel-specific functions. I will give it a try.
    Jun 2005
    180
    Deleted.
