587,240 active members*
3,785 visitors online*
Results 1 to 7 of 7
    Nov 2007
    Drilling aluminum
    Hi all. I am not a machinist by any means, but i have a (maybe) dumb question.
    I have some 3/8" thick 6061 AL plate that i want to drill a 22mm hole through. Also, on the same center I'd like a 28mm hole halfway through, as the picture shows:
    However, I only have limited tools - a handdrill, a drill press, etc...
    Question: is it possible to do this with the tools i have, assuming i am will to spend a few bucks on bits or whatever? Would a combination of spade buits work? Also, it is not necessary to have it super accurate.
    Byron
    Jul 2005
    12177
    Nov 2007
    hmm..for some reason my search yielded no fruit - thanks a lot!
    Byron
    Jul 2007
    12
    Quote Originally Posted by mantisory View Post
    Byron
    If you clamp workpiece down to drill table you should be able to drill a pilot hole say 5mm then drill out to 22mm dia try and use the bright finish drills as the alum sticks to black(steam finished drills)you will need a counterbore with a 22 dia pilot for a one off you could get a piece of 22 dia round and cross drill say a 5mm hole to take a brocken centre drill and sharpen this to give a single point cutting tool its easy for me as I was a toolmaker send me your email address I will draw up a sketch of what I mean regards shiney
    Dec 2006
    532
    you could get forenster bit to do big hole, works pretty good on aluminum, just use some lubricant(wd 40 or similar).
    Dec 2006
    242
    Send it to me with return postage and a $5 bill. I'll CNC it dead on. I'm slow right now. Priority mail flat rate is $4.20.
    Nov 2007
    davereagan, thanks for the offer, but i will be trying the Forstner bit this weekend i think - i need to finish up this project soon
  1. deep drilling small holes in aluminum
    By Fremont Dave in forum MetalWork Discussion
    Last Post: 11-25-2007, 08:03 AM
  2. Drilling large holes in aluminum
    By watsonstudios in forum Uncategorised MetalWorking Machines
    Last Post: 05-03-2007, 01:55 PM
  3. drilling and drilling cycles tutorial
    By wmorre in forum MetalWork Discussion
    Last Post: 10-19-2006, 12:30 AM
  4. Drilling Holes in Aluminum
    By JavaDog in forum MetalWork Discussion
    Last Post: 09-09-2005, 03:29 AM
  5. Question about drilling Aluminum
    By cross6 in forum MetalWork Discussion
    Last Post: 11-15-2004, 03:12 PM
