587,180 active members*
4,884 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > portable and lightweight fixed-gantry router - water filled tubes?
Page 1 of 3 123
Results 1 to 20 of 52
    Jun 2010
    I'm looking to built a small, portable fixed-gantry router.
    The lightest weight ones I have found are around 30kg, with an A4 or A3 sized working area. This is pretty light, but perhaps not quite light enough.
    From what I read, most people advise going for the heaviest machine possible, using thick aluminium or steel for construction, so as to avoid vibrations.
    Since the machine needs to be portable, it needs to be as light weight as possible, which rules out using very heavy aluminum or steel sections.
    I read about people using epoxy-granite, or filling their sections with sand, and wondered if a machine made from welded, connected, hollow sections could have those hollows filled with water, thus doubling or tripling the weight of the machines on-site.
    Drain the water for transport, refill at the destination.
    Thoughts anyone?
    Jul 2005
    12177
    All the water would do is increase the weight it would not significantly reduce any vibration. Epoxy-granite and sand are solids which dampen the vibrations water is not solid and doesn't dampen vibrations as effectively.
    Jun 2010
    I wonder if filling the interior space with an open-cell or reticulated foam of some kind, much like the anti-slosh foams found in fuel tanks, would increase the damping effect.
    EvoMx Inc. » Fuel Tank Foam Information
    Safety Racing Fuel Cell Safety Foam - Speedway Motors, America's Oldest Speed Shop
    There's an paper here on fluid filled foam damping, but I dont have access to it
    Mechanical Damping in Liquid-Filled Foams | DeepDyve
    Here's another paper on gas-filled open cell foams
    Cellular plastics: proceedings of a ... - National Research Council (U.S.). Committee on Foamed Plastics, U.S. Army Natick Laboratories - Google Books
    Heres another approach which gels the water with a superabsorbent polymer, effectively creating something like a reticulated foam but at a molecular scale. Question is - how do you drain the water out of the polymer for transport?
    http://www.google.com/patents/about?...BAJ&dq=5472761
    Oct 2005
    2392
    In machine design I like to think a while about the problem before designing the solution...
    Why does it need to be portable? Do you need to take it to work or college or to a friends house etc? So that means it also needs to fit on a car seat or in the trunk?
    It might be better to build it in two pieces, like the base piece and then a removable gantry piece that also has the spindle etc. The PSU box might be a third piece.
    Then that would be easy to carry and transport but might require 3 trips to the car to carry each of the 3 pieces. Which is why it's a good idea to really think through the problem (the requirements) first...
    Jun 2010
    Quote Originally Posted by RomanLini View Post
    Portable, to me, means shipping it internationally, several times a year. This means that shipping weight and volume are important.
    Ideally it should be able to be packed into something that can fly as checked luggage.
    If it can be cut down from 30kg to 15kg - that means 1000s of dollars saved over the life of the machine.
    Oct 2005
    2392
    Well that's handy information!
    But what does it need to cut? If you can reduce the cutting area that makes the machine smaller and lighter, and if you can reduce the tool size and cutting power that allows a small lightweight spindle and smaller stepper motors and smaller PSU/drivers etc.
    And small tool size and reduced cutting power mean you can use a less rigid machine so that opens up options of a lightweight plastic frame build. Maybe fibreglass or carbon fibre tubing? I think you can buy both types in rectangular tubing.
    A really neat solution would be to design the machine to fit in a single suitcase or travel case, all custom fit so you just get to your location and open the case and plug it in.
    Jun 2010
    Needs an A3 cutting area (about 12x16 inches), and needs to cut aluminium and plastic. In general, if the parts are large, they will tend to be from thinner/lighter material.
    It doesn't need to be very fast, but it should be as precise as possible, given the weight constraints
    My impression is that a fixed-gantry, moving table design might be the right way to go.
    I thought about laying up carbon fibre over open-cell rigid foam, which can then be water-filled.
    Jan 2008
    853
    walking on water
    Hey, I just had an idea on this, and I want to write it down before it flies away.
    I agree that water does not damp the vibrations, it is too fluid. I agree that sand does, because it offers resistance to displacement, but it may be tough to fill a tube evenly.
    What about the non-Newtonian fluids that you see in YT videos, mostly made of corn starch and water. Under low accelerations and forces it behaves as a liquid : no problem because at gentle changes of speed and direction you don't need damping. But if the machine tries to buck or vibrations want to set in, the fluid turns viscous and damps motion quite effectively. If you stand in this stuff you go down to the bottom, but if you jump onto it it will firm up under your feet and you can walk-on-water. Until you stop walking, then you sink.
    Viable?
    Jul 2009
    690
    What about MDF with a torsion box-based design? that can save a lot of weight while mantaining rigidity.
    Jan 2006
    2985
    I think a Widgitmaster Wide might be just what you are looking for. Its not really built for machining aluminum, but if you are only working with thin sheets it might be ok. It would break down to fit in a suitcase quite easily.
    Widgitmaster, Inc.
    Matt
    Apr 2009
    134
    check this out:
    http://zeed-diyproject.blogspot.com/
    Jun 2010
    Quote Originally Posted by PaulRowntree View Post
    I think I came across some articles about using non-newtonian fluids as dampers.
    I think that there is an equivalence between a gel, a water-filled foam, and a non-newtonian fluid, in that all of them present impediments to clean fluid flow.
    Jun 2010
    Quote Originally Posted by keebler303 View Post
    Widgitmaster, Inc.
    Matt
    I've seen the widgitmaster machines, and they are absolutely lovely.
    At 18kg, the Wide router is in the weight range.
    What makes you say its not suitable for aluminum?
    Oct 2005
    28
    Quote Originally Posted by zeed View Post
    check this out:
    Didn't see anything being cut.
    Apr 2009
    134
    Quote Originally Posted by jacmarhal View Post
    Jan 2006
    2985
    Quote Originally Posted by dmorton View Post
    You have been quite vague about your desired parts so its hard to say. A 12" x 16" aluminum part would take some serious time to cut unless it was merely cutting holes in a sheet or something. You are talking about something like 0.01" passes in aluminum. The Widgitmasters are sweet, we have a midi here, but I have never cut metal with it. It might be fine for you, but since I have no idea what you are cutting, I just wanted to mention that it would probably not be the best choice for daily aluminum cutting.
    Matt
    Nov 2010
    114
    this looks more like a magnetic drill to me, how will the material be hold? its an onsite hole milling machine, not cnc table.
    Going minimalistic, many decisions have to be made.
    What would you like it exactly to be able to do and what rails will you use, that's the main question, also not to forget that the electronics should be inside the machine for commodity.
    What spindle or router.
    In 2 words-first you have to be sure exactly for what you need it and then design it, as sb mentioned -in a case
    Jun 2010
    The range of jobs I have in mind is wide - aluminium panels, motor mounts, bearing housings. Sorry if I am vague, but the uses are manifold.
    An example of a part I really would like to make now is a mold for making connectors for 2x4 inch fiberglass tube. This would be made from aluminium or plastic. A top and bottom half, each about 1.5x6x6 inches.
    The thought of doing 100 passes per inch isnt very appealing. Would want to do maybe 10 passes per inch.
    Nov 2010
    114
    square supported rails over steel welded construction and HF spindle, moven by ball screws on all axis is the answer.
    i can cut with my belt driven 1-3mm Romax HS1 / by the way is 60kg/ deep in aluminum but don't do it cause will %&& the V bearings very fast, so i know what is to make many passes with Al, and to tell you the truth i am already looking to build for my self exactly what advised you
    Mar 2004
    439
    Well, if you wanted to go to the extreme, you could try out a hexapod:
    RoboFac
    The one on this website is clearly not rigid enough for cutting aluminum, but this approach could have potential, and due to a "space frame" could be built with minimal weight, as all the cutting forces are through the axes of the actuators.
    I believe that there is a EMC Linux add-in that coordinates the 6 axes and runs g-code, but there aren't many users out there that I have found.
    I have always wanted to try making something like this... Need more time for hobbies!!
    An alternate approach would be to make a small gantry from high quality steel stages (THK KR stages/ Hiwin KK) that could be disassembled and rebuilt. Using removable tapered dowels at the bolted joints would allow the machine to be reassembled and be reasonably accurate without having to square the machine all over again. Search ebay for THK KR and you will see many of these great stages. They have a steel base, and they integrated the ballscrew and the linear ball bearing block to make it very small and very stiff.
    Keith
Page 1 of 3 123
  1. New DYI Fixed Gantry Router Build
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:45 PM
  2. Fixed gantry router
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 04-17-2011, 11:44 PM
  3. fixed gantry router built in solidworks
    By dlpaul in forum DIY CNC Router Table Machines
    Last Post: 02-08-2011, 09:40 PM
  4. Fixed Gantry Router Bearing Position Q?
    By Gliderask21 in forum DIY CNC Router Table Machines
    Last Post: 11-26-2010, 11:37 PM
  5. New Haas Lightweight Router, Info?
    By dansutula in forum Haas Mills
    Last Post: 09-06-2006, 04:41 PM
