587,571 active members*
3,692 visitors online*
    Jun 2007
    RFQ: Lasered stainless pieces.
    Need 8 of each cut from 1/16th inch thick stainless steel.
    I need to tolerances to be semi tight. I would like to keep these pretty cheap. They are for prototypes and I will be ordering more later on. The small holes are to be cut or drilled for 2-56 and the larger holes for 6-32.
    Attached Files Attached Files
    Mar 2006
    6
    Dear
    I'm interested in your RFQ, I'm lily from Jingyi metalwork Co,.Ltd in China. Can I know you do you plan to purchase from China? How much your next order? If I can help you, please forward more information to me by e-mail [email protected]. Also I think you can get some indication for our factory from www.bright-lucky.com.
    Best Regards
    Lily
    Jun 2006
    12
    need to know what type of stainless, 304,316, 17-series, 410, 420. and what condition hardness.
    also the small holes are going to be tapped or clearance holes? quote or not to quote?
    Dave
    [email protected] ILLINIOS USA
  1. RFQ 500-1500 pieces
    By bladestalker in forum Employment Opportunity
    Last Post: 11-24-2006, 12:48 AM
  2. Bits and pieces
    By dagdaj in forum CNC Tooling
    Last Post: 10-17-2006, 10:11 PM
  3. 40 pieces to start off with, then more
    By Crazy Phantom in forum Employment Opportunity
    Last Post: 03-30-2006, 12:33 AM
  4. RFQ- Hub pieces
    By pinkerton5 in forum Employment Opportunity
    Last Post: 01-28-2006, 03:41 PM
  5. Opinions On These Pieces?
    By sbrpollock in forum DIY CNC Router Table Machines
    Last Post: 08-20-2003, 08:03 PM
