I just got the wiring in to my Roto-master motor type phase converter for my (1991) KM3P.
As luck has it the legs were out of phase so the motor ran backwards... no big deal right, - Wrong!
The speed adjustment motor started turning to set the spindle @ 2000rpm - going the wrong way and went way beyond the normal scale before it was shut down.
Now I need to know how to get things back in sync without blowing the head up.
I can start the spindle in manual and use the over-ride momentary switch to adjust speed but - if you don't use the over-ride the speed control tries crank the speed up well past 4000 and only stops when it binds.
The belts in the head are less than 18 months old, and have had very few hours on them thanks to the economy. So at least those should still be in good shape.
I'm not sure if I need to swap wires for the speed adjustment motor or what at this point. I spent about 6 hours going over the all the different machine manuals and there is lots of great info there, just nothing which applies to my issue short of how to tear down the head completely.
It seems the limits were ignored because while it "thought" it was turning the speed down towards the lower limit while it was really approaching and passing the upper limit.
I'm sure I'll have other issues to work out since the move. Last time I ran a Max II KM3 was about 2000 or 2001. This machine has the Max32 with the 3D option - so many updates and improvements, its going to take a bit to get fluid with it again.
I also have 4 matched 30 pin simms to install in the 4 empty sockets.
And I guess I should also check all the motor brushes too. - This is beginning to feel like WORK!![]()
