588,445 active members*
5,326 visitors online*
Results 1 to 9 of 9
    Mar 2004
    156
    Wiring Questions
    LInk
    On the diagram above, what is fuse block use for? I have a 24v 12Amp power supply, can i wire it directly to my driver board?
    Apr 2004
    439
    It's there for safty not to over load the gecko andor wires
    you can run direct but basic fuse protection is a good idea.
    Mar 2004
    156
    thank you
    how can tell what size of fuse you need? I have 24v 12amp power supply for 3 axis stepper motor. each axis is going to run 4 amp.
    Apr 2004
    439
    what controller do you have? or what it's max amps?
    stepper can take overload on the amps alot more then the controller. so most time you fuse to protect the controller. also you have to make sure the fuse is still smaller then the max amp size of the power wire.
    Mar 2004
    156
    i got Oregon Micro System MH10. and Powermax II model: p22NSXA 3.3amp bipolar series, 6.5 bipolar parallel. Link to data sheet. On page27 table 7 shows the current chart.
    also i have 5v 15Amp power supply, do i need limit down the current before connect it to circuit board?
    thanks for you help.
    Apr 2004
    439
    pdf says to use a 5amp fuse. sounds good. make sure you use the wiresize listed in the pdf. also you shouldnt need to limit as it looks like a mircostepping controller.
    But you should read the pdf and make sure as i dont want to be the person that told you something wrong and it burned out your controller
    goodluck
    Mar 2004
    156
    Where did you see the size of wire in PDF?
    Apr 2004
    439
    page 5 "installation"
    Mar 2004
    564
    think of amperage as "flow" through a pipe (GPM), voltage is the pressure in the pipe and resistance is a blockage in the pipe.....your machine will only pull as much amperage as it needs to do the work. so some math needs to be done to determine wire sizes, fuse sizes ect.... one fuse on the system is a good start but you need to isolate the different systems from each other to ensure safe operation.
  1. Wiring help.
    By dmgdesigns in forum CNC Machine Related Electronics
    Last Post: 04-17-2005, 05:12 AM
  2. Wiring Question
    By The Wizard in forum CNC Machine Related Electronics
    Last Post: 01-04-2005, 07:11 PM
  3. E-Stop Home/Limit Questions
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 10-09-2004, 07:40 PM
  4. 4-phase motor and wiring questions
    By DmitryZ in forum CNC Machine Related Electronics
    Last Post: 04-14-2004, 05:14 AM
  5. Stepper Motor Wiring Questions
    By TRC1 in forum CNC Machine Related Electronics
    Last Post: 08-16-2003, 03:03 AM
