588,199 active members*
4,739 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Star VNC 32 Blowing fuses on startup.
    May 2012
    6
    I think it's in the power board, a 3.2 amp that blows every time we turn it on. I've tried to take pics of where it is located.
    Attached Thumbnails Attached Thumbnails 20130211_190435.jpg   20130211_190500.jpg
    24220
    If it is on the I/O board, try removing the I/O Honda plugs and replace one at a time to assist in locating the source.
    If the fuse stays in, then check the particular wiring and devices fed from the offending Honda plug.
    Al.
    Albert E.
  1. TNC145 blowing fuses
    By Mike Woo in forum Bridgeport / Hardinge Mills
    Last Post: 01-24-2019, 12:15 PM
  2. Blowing 20a fuses!
    By fgwilson99 in forum Community Club House
    Last Post: 04-28-2011, 02:13 AM
  3. Blowing 4amp Fuses
    By tajord in forum Hobbycnc (Products)
    Last Post: 02-27-2007, 02:03 PM
  4. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
