588,568 active members*
4,839 visitors online*
    Aug 2011
    where do you buy your foam?
    do you buy them in preformed blocks?
    Also can you cast your own? Like those spray on stuff for house insulation?
    Feb 2009
    6028
    The craft store.
    Oct 2011
    104
    I'd like to know this too, i've been scouring the internet for hours trying to figure out what kind of foam to us for high detail CNC work.
    Jan 2006
    2985
    Well this forum is meant for wire cutters so you would want to use a polystyrene or other thermoplastic foam. Most folks use blue or pink foam from the home improvement store for that.
    If you want to carve or route detailed shapes into foam, I would recommend Precision Board from Coastal Enterprises. They have a wide range of densities, sizes, all the fillers and adhesives you need and they will send you a sample to try. I like the stuff a lot.
    Home | Coastal Enterprises
    Matt
    Dec 2010
    Using 2lb EPS can and does produce quality work. you can get it at numerous block molders in the usa. In Texas Starrfaom is about the biggest. I know they have a place in AZ too.
  1. EVA Foam
    By Doc B in forum Want To Buy...Need help!
    Last Post: 01-07-2024, 04:05 AM
  2. How to cut eva foam?
    By geminni024 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-07-2024, 04:04 AM
  3. Where to buy Foam
    By skipper in forum CNC Wire Foam Cutter Machines
    Last Post: 02-23-2010, 05:57 PM
  4. 3D topographical map routered out of foam foam
    By 3Dmap in forum CNC Wire Foam Cutter Machines
    Last Post: 08-26-2007, 01:55 AM
  5. What is foam cut and used for?
    By WarrenW in forum Material Machining Solutions
    Last Post: 12-06-2006, 04:48 AM
