I committed myself sometime ago to design another handheld pendant. There are some nice and powerful designs around, but there is enough space for improvement (price-wise, usability, etc.).
This is the brief description of scope of the design:
- Handheld pendant to be used with Mach3 (at least in the initial version);
- USB and / or RS232 connectivity, RS422 optional (for long cables);
- LCD with DRO for 4 axes, selectable; some other functions will be displayed on the LCD as well;
- Jogging on 6 axes (selectable) with: MPG (for the standard version) / keyboard jog (for the light version); Continuous / Step selectable; x1 / x10 / x100 selectable;
- Feed rate override control;
- Spindle and spindle direction control;
- Some buttons are programmable, the function can be changed from the Mach3 plugin;
- Cheap and simple electronic control board, microcontroller based;
- All the selections are push-button style, with memory for the last position and retrieval of the position from Mach3.
There are some other features not detailed here, but these will be revealed during the build log.
I designed two preliminary versions, made some mistakes, learned, and played with the prototype file sets from Mach Support forum (thanks art, jemmyell, poppabear, and all the others that contributed). I have the skeleton of both the firmware and the plugin software, much more to be done .
I am waiting for the new pcb's and the components to come, I will keep posting once I have new facts.
Below you can see two images of the (wrecks) of v0 and v0.1 pendants, and the simulated images of the light and standard version of the actual version.
Please keep posting any opinions and ideas, thanks!
Florin
