588,684 active members*
6,252 visitors online*
    Jan 2006
    16
    CMT problem mazak t32-2
    Im using cimco software to link my t32 to a pc to store all my programs,my problem is i cant reload the programs back into the t32. I can save the programs, and veiw the programs on the pc via the controller, but when i go to load the program i keep getting the cmt misconnected error(error 515), the mazak alarm list is telling me that my cable is misconnected or a paramerter is set incorrectly. i dont have a clue how to set the parameters and if the cable was misconnected i would not be able to view or save the programs . I need help, getting very frustrating.
    24222
    If you have a fully populated cable right now, try using a 3 conductor with handshake jumpered, see the www.cadem.com site for cable & Parameters http://www.cadem.com/ncnet/dnc-detai...zak-t32-m2.pdf
    Al.
    Albert E.
    Apr 2014
    11
    Re: CMT problem mazak t32-2
    we have the same problem today
    how did you fix it
  1. Problem with Mazak VQC 20/40
    By Pro24 in forum Maintenance DIY Discussion
    Last Post: 09-13-2012, 02:37 AM
  2. Mazak ATC Problem
    By chippah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-15-2012, 05:19 PM
  3. Mazak 610 problem
    By FELMAR in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-13-2011, 07:23 PM
  4. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
