588,684 active members*
5,883 visitors online*
    Sep 2007
    35
    Haas X Axis Taper Moves?
    Just wondering is any one having problems when they try to taper very small amount in in (X) on the haas lathe?
    Say im doing a 1.5" pin thats 12" long with a tail center in it.
    The OD is 1.499 -.0000 +.0005 (17-4 SS)
    Any one ever have problems with the machine stepping, or leaving steps when trying to correct taper?
    If I do a (-X) taper some times I get a step down, and it leave a mark.
    If I do a (+X) taper it seems to be ok.
    Jul 2005
    12177
    What is a small amount?
    I tried a taper of only a few thou over several inches and it was not smooth. I think it is that when the taper is small the taper per inch is close to the machine resolution so it goes in .0002 then cuts for a while then goes in another .0002. I couldn't figure out any way around it.
    4826
    Is it possible that the lathe is running in exact stop mode? This might create a small dwell mark for each command.
    One good feature of the Galil motion card I used in one lathe retrofit, is the ability to load an entire sequence into the command buffer and execute it with zero delay between commands. This seemed to be the secret to a blended appearance on a flexible part.
    Or maybe there is a parameter for "in position check" that you could temporarily modify for this job.
    Jan 2008
    575
    HU and Geof I'm sure know better than me, but won't that control accept a U value in the same line as the Z- line? ie Z-3.U-.0002. Robert
  1. X-axis moves position while running
    By will@djg in forum DNC Problems and Solutions
    Last Post: 10-13-2008, 06:40 AM
  2. My Z-axis moves upward during 3D contouring
    By Khalid in forum WoodWorking Topics
    Last Post: 07-15-2008, 12:56 PM
  3. Y axis moves backwards on X3
    By hodge98ws6 in forum Syil Products
    Last Post: 04-10-2008, 08:57 PM
  4. No A axis moves ? ( in post )
    By Scott_M in forum FeatureCAM CAD/CAM
    Last Post: 08-09-2007, 02:37 PM
  5. Converting G2 & G3 Moves to Rotary Axis?
    By skibbey in forum G-Code Programing
    Last Post: 04-03-2007, 01:40 PM
