Hope I can get some help. I want to build a 48x48 plasma/router table.
X and y I plan to use 1 inch round shaft with open linear bearing blocks so I can support the shaft midway. I plan on four 425 oz 8 wire steppers with controller and power supply from Xylotex. I plan to use two motors on y..one on each side direct driving acme screws possibly 1/2 x10 or 3/4 x 6....any
ideas or suggestions on the acme part. I may just bush Z. I have a small
lathe and mill so I can do quite a bit of the mechanical part myself. My shortcomings are related to controllers, software, power supplies etc. I've
torn motors apart for years to make things but never messed with cnc and steppers yet. I built a 300 lb radio controlled skid steer 4 wheel robot thing after watching BattleBotts, to pick up my paper during bad weather days(only once) but used it for about everything else so I know I can make this
table. I would rather have input from people that have already success and
failure so I can learn what not to do. Any and all replies will be welcomed.
thanks..............nick :cheers:
