588,487 active members*
5,342 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Tool Release Piston Failure?
    Sep 2006
    251
    Good Morning Everyone.
    I have a 1998 VF-10 (serial# 16018) that keeps breaking the snap ring on top of the piston shaft. I just finished last week replacing the complete tool release piston assy., due to it had broken the piston shaft also. A brand new assy. and it has already broken the snap ring again. I have checked the pre-charge pressure, and it was set @ 18 PSI. I adjusted this down to 6 PSI, and was wondering if that could cause a snap ring failure. This machine has TSC, but is used rarely (twice a year). Can anyone give me an opinion or a fix?
    Any help is greatly appreciated!:cheers:
    Just a good ol' boy, never meanin' no harm.
    Joe
    Sep 2006
    48
    Has the TSC been used since the new piston was installed?
    Pre-charge pressure too high can cause the shaft to spin, vibrate, tear up...
    Do you have a service manual? Did you adjust the drawbar pushout correctly?
    What is the main air regulator set to? If set too high it can cause the TRP o-ring to blow out.
    Are tools sticking in the spindle?
    Loose nut
    Sep 2006
    251
    Quote Originally Posted by Loose Nut View Post
    Loose nut
    Nutty,
    I tore this back apart to replace the snap ring. I had to add .020" shim to the piston screw. According to the manual, I now have it adjusted properly. Pre-charge is set to 6 PSI. Main air is set at 85 PSI. No, the tools don't really stick in the taper. I have re-assembled and hope the .020" does the trick. Thanks for asking questions. It helped me to see what may have previously been overlooked. Two heads may be better than one?:cheers:
    Joe
    Mar 2008
    95
    How much drawbar pressure do you have?
    Sep 2006
    251
    Quote Originally Posted by rlabonte18 View Post
    riabonte,
    I thought the same thing. Checked it with a new "Clamprite" gauge. It is showing 1150 lbs. of clamping pressure. The manual calls for 900 - 1300 lbs. to be in the safe range.
    Joe
  1. VF2 SS tool change failure
    By omy005 in forum Haas Mills
    Last Post: 07-09-2009, 08:39 PM
  2. Tool unclip failure
    By Shotout in forum Haas Mills
    Last Post: 08-10-2006, 02:03 AM
  3. Tool Turret Index Failure
    By hatchmar in forum DNC Problems and Solutions
    Last Post: 06-10-2005, 12:36 AM
  4. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
  5. Tool Release Button,
    By Ken_Shea in forum Haas Mills
    Last Post: 08-05-2003, 02:27 AM
