588,055 active members*
4,556 visitors online*
    Oct 2008
    115
    Watch hands froms 0.25mm - 0.3mm mild steel
    I'm looking for a quote for approx 50 pair of watch hands cut from mild steel plate. ( Hands will be heat treated to a blue color , not sure which would be the best steel to use, we can discuss this.)
    Thickness of hands 0.25mm- 0.3mm.
    See attached DXF for shape and sizes
    Size of hands are approx......
    hour hands 14.05mm centre-tip, and 2.05mm wide
    long minute hand 17.75mm centre-tip, 1.48mm wide
    I'm guessing stamping would be the ideal way to do this, but tooling costs may be too high. So......water cut? laser? or ?
    best regards, Kalvin
    Attached Files Attached Files
    Dec 2004
    783
    Maybe photo-etch? Or edm
    Jul 2011
    watch hands
    Have a shop with wire capabilities do a stack burn with blue spring steel
    Should not cost to much
  1. RFQ Mild Steel Mill Job
    By C.Logan in forum RFQ (Request for Quote)
    Last Post: 08-20-2012, 03:04 AM
  2. cut mild steel?
    By dharps in forum DIY CNC Router Table Machines
    Last Post: 04-01-2011, 03:33 AM
  3. RFQ: Looking for someone who can make watch hands
    By amanson in forum Employment Opportunity
    Last Post: 08-01-2008, 01:26 AM
  4. Mild Steel
    By MBG in forum MetalWork Discussion
    Last Post: 03-09-2007, 11:20 PM
