588,033 active members*
5,662 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    Mar 2006
    34
    Rigid Tapping
    Does anyone have experience rigid tapping with a Cent6 controller? My mill is supposed to have this option, and I would like to learn more about. Am I understanding correctly that you can chuck a tap up in there using say an ER-32 collet and program tapping? If so, what would be the better to use cut taps or form taps?
    Thanks for any information.
    May 2006
    50
    Yes you can put your tap in a collet. the type of tap depends on what you want to do. material blind hole thru.
    if you have rigid tapping you will need to have tap collets, they will hold on to the square end of the tap.
    form vs cut
    6061AL form or cut
    brass cut
    copper form
    anything cast cut
    1018CR cut
    most CR lead steels form or cut
    tool steels cut or thread mill
    SST cut or form
    if you have to pound a blind hole into some material
    that you can form tap its best to use one. If not you can use a spiral fluted cutting tap that will send the chips up the tap not down like other cutting taps.
    hope that helps
    feel free to ask more questions
    Apr 2004
    124
    I tap with collets all the time, just got to make sure there tight. BTW, rigid tap on a cent 6 is a G88. Todd
    Mar 2006
    34
    Thanks for the reply guys. I'll have a chance to play with with it tonight and see if my mill supports this feature. The original owner had a hodge-podge of add-ons and didn't go with the package upgrades. I'm hoping this is one of them.
    May 2006
    196
    I haven't done any rigid tapping on my Cent.6. I have on my Cent.5. I don't know how familiar you are with the conversational side of the controller but they make it very easy to figure it out. Some guys don't care for the conversational programming, but I do a lot of prototype molds, and sometimes nothing can touch the speed in which I can create the program. I also use regular collets. I would have to say if you can use a form tap that is the way to go, especially in a blind hole. No chips
    Mar 2006
    34
    I attempted to do some hard right tap cycles and no love. The table moves in X/Y but no movement in Z. After looking through the documentation that came with the mill, the previous owner had a sheet of G and M codes hand written and next to G88 there is "Hard Tap (Not Avail)"
    So, it looks like I'm out of luck
    Looks like this is a $1200 option currently. I don't know that I would do enough tapping to justify that much money. I could put that towards a dedicated tapping table.
    Thanks for the help and quick replies.
    James
    Feb 2006
    24
    Rigid tapping works in a standard collet I have even used a drill chuck
    I will agree with you guys, Rigid tapping will work with standard collets but be careful with your RPMs. I will some times rigid tap at 8000 to 10000 RPM and at those RPMs you need tap collets.
    Apr 2004
    124
    8-10000 rpm? Whats the point of that? In what kind of mat'l?
    some of our jobs are very high production 5000 to 10000 pcs. per order so if i can decrease run time at all its worth it. i have cut taped and form taped at 8-10000 rpm in AL, brass, and copper. keep in mind those were not very big taps (6-32 up to 5/16-18).
    Mar 2006
    34
    Does anyone know exactly what one gets for $1200 with the rigid tapping feature from Milltronics? I mean is there some hardware they add or are they simply turning on an option in the setup?
    Feb 2006
    24
    I cant understand why anyone would tap at 10000 RPM Itwould take longer to excell and decell than you could savr
    bill that is not tru. try it if you can or dare. I will start .100 above the part and by the time the tap hits the part its 10000 rpm. This is done on your Brother TC-22 VMC, some VMC might not beable to handle this.
    Feb 2006
    24
    I bet if you taped a series of holes @ 10000 then did them again @ 5000 there would be very very little time difference.
    Dec 2005
    61
    The rigid tap option gets you a encoder and belt and cables.
    You will then need to tell the control it has rigid tap.
    what is the serial number of your machine I can tell you if it was buildt with rigid tap.
    Apr 2003
    637
    Ok, I've done a number of tapped holes without a glitch until today. I programmed 4 holes .500 deep at 1000rpm and the machine tapped 1.000 deep! Now I have a broken tap in a blind hole in a $600 piece! I changed the depth to .250 deep and it still tapped 1.000 deep! Then I changed the RPM to 500 rpm and it works as it should. What gives? What does the RPM have to do with the depth.
    Here is the code generated in Surfcam:
    O1
    G90G80G40G17
    T19M6
    G0G54X-0.886Y-4.252
    M3S1000
    G43Z1.H19
    M8
    G88G98X-0.886Y-4.252Z-1.489R-0.889F0.05
    X0.886
    Y4.252
    X-0.886
    G80
    M5M9
    G32
    G49M2
    This is a VM24 and Centurion 6 controller.
    Apr 2004
    124
    Well, For starters on your G88 line your asking it to tap Z-1.489 deep. So the fact that it only went down to 1" is amazing. your R plane with an initial height of Z-.889 is blow Z, zero. So i hope that your part Zero is - 1." from mat'l top or you asked it to tap more than 2" deep. With -1.489 - -.889 that still is asking it to tap .6" deep. if mat'l top is Z "0" then you would wan't your G 88 line to read G88 G98 X, Y, Z-.5 R.1 F.05
    Apr 2003
    637
    Sorry for the confusion, that particular post was from a set of four holes in a pocket that was .989 deep. If that confuses you, then here is a post with the holes at Z zero:
    O1
    G90G80G40G17
    T19M6
    G0G54X-0.886Y-4.252
    M3S1000
    G43Z1.H19
    M8
    G88G98X-0.886Y-4.252Z-0.5R0.1F0.05
    X0.886
    Y4.252
    X-0.886
    G80
    M5M9
    G32
    G49M2
    Could someone try this on their machine and see if it goes one inch deep? Then change the rpm to 500 and see what happens.
    Apr 2004
    124
    I'm wondering if your spindle encoder is working properly. It shouldn't overun that much or at all. I've done a lot of tapping with a cent 6 and 7, never had a problem. I don't have one available right now.
Page 1 of 2 12
  1. Replies: 1
    Last Post: 07-06-2014, 04:44 AM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  4. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
