588,270 active members*
12,154 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Automation Technologies (Keling, Inc)
    Oct 2012
    Just received this kit (CNC Stepper Motor Kit: , Stepper Motor, Servo Motor, Power Supply Automation Technology Inc) and building the Solsyvla 10x9 Table. I noticed the walls of the motor do not allow the head of the machine screw to remain square; using a Phillips pan head, Stainless steel 18-8, #10-24 x 3 Machine screw.
    Anyone dealt with this before and able to offer a different size screw that would provide better fitment.
    Feb 2009
    1290
    use a Socket Cap Screw.
    Socket Cap Screws | Fastenal
    Thank You.
    Mar 2011
    584
    Drools beat me to it.
    Dec 2008
    292
    Or, just mount the bolt in your power drill (clamp the threads), and turn the sides of the bolt head down on your grinder or belt sander until the bolt fits thru the stepper mount holes and remains straight. This is a common problem. Using the cap head screw as suggested will also work just fine.
    Don
  1. CNC4PC and Automation Technologies
    By DRock in forum CNC4PC
    Last Post: 02-18-2015, 02:33 AM
  2. Keling 5056D, Keling C10 BOB and Mach3 problem.
    By DrewSmith007 in forum Automation Technology Products
    Last Post: 04-27-2013, 06:21 PM
  3. Nordic Automation / Eu-Automation
    By Swemill in forum Norwegian
    Last Post: 03-15-2011, 01:10 PM
  4. Gecko 540 + Keling Power Supply + Keling Steppers - Good combo?
    By metricmike in forum Uncategorised MetalWorking Machines
    Last Post: 11-19-2010, 09:53 AM
  5. Keling Servos ===> Keling 10:1 gear reduction.
    By diyengineer in forum DIY CNC Router Table Machines
    Last Post: 09-28-2010, 12:22 PM
