588,668 active members*
6,473 visitors online*
    Aug 2005
    36
    pdf to bobcad
    can you inport a pdf file to bobcad v20
    Aug 2003
    449
    BobCAD does not support pdf as an import type. However, you may be able to import the pdf as an object that can be viewed on the CAD screen. (Edit => Insert Object) When using this method you will have to create the geometry over the image, because the object itself will not be actual geometry.
    Regards
    Oct 2006
    7
    you other option is to bring the PDF into something like Corel Draw or Cadkey and save as DXF
