Originally Posted by
dookie2022
Yes you have to pull the whole assembly apart and knock the the pin out and replace with a new one but refer to parts manual for pin depth as this is important.
Also note how the bearings are mounted in the guide bush assembly as they have to be put back the same place to help maintain balance and the thrust bearings in the correct direction.
I'll take that one step further.
I would suggest that if you have the bearing out, to just replace them with new.
It's going to take an hour to get everything apart and disassembled, you might as well spend the $220 buck and put new in.
Not to mention that these rarely just "shear" off.
It's usually the result of some type of catastrophe which most likely caused some bearing damage; even if the seem ok now.
But that's just me.
Good Luck.
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
