587,370 active members*
3,623 visitors online*
Results 1 to 8 of 8
    CNC Parallel Port to USB
    Hello, I'm new here and new to the world of CNC.
    I've just got my hands on a CNC, it's a 6040 Chinese one. I got it 2nd hand off ebay.
    It has a parallel port on the back of it, and I don't have anything that will run that. I'd like to know if this planetCNC product https://planet-cnc.com/product/cnc-u...r-mk34-4-axis/ Will solve my problems?
    My set up is:
    Apple Macbook with USB3 (The wife wants to use illustrator and then export as DXF)
    6040 CNC with Parallel Port.
    But we have 2 issues:
    1 - Software - I see planetCNC works for Mac, big tick.
    2 - Middleware signal conversion
    Any help would be greatly appreciated please
    Jan 2022
    107
    Re: CNC Parallel Port to USB
    This hardly depends on the informations which are available of the prallel port type...
    Asuming the "parallel port" is just used for step dir signals from the software, there is knowledgement of the internal circuit required to build an adaptor. If there is additional hardware behind the parallel port, this would not help.
    To say anything useful. It is required to know more about everything what comes internally behind the parallel port connector...
    Jan 2018
    1516
    Quote Originally Posted by Trizzyrascal View Post
    My set up is:
    Open up the control box, take some images and upload them so we can see it.
    USB to parallel requires extra circuitry, it isn't a simple converter.
    Honestly the easiest way:
    You are batter off getting a USBMach controller board (red square one) to replace the parallel one and rewiring the internals to it. Then using Mach3 to control it.
    Hardly anyone uses a Mac o.s. for cnc. It's Windows or Linux.
    The next popular route:
    Buy a cheap dell desktop pc that has a Parallel printer port with Win7 or WinXP 32bit and use Mach3. Have this pc dedicated to the machine alone.
    Updates can cause issues.
    The cnc you bought should have had a license for Mach3 with it if you were given the installation disc with it.
    Then there is the UC100 which is a true USB to parallel converter for use with UCCNC or Mach.
    May 2007
    15
    you can make an PCB with an arduino nano and a parallel port output, then you can use the usb port.
    using GRBL as software. Just plug in the nano with parallel port on your existing machine. I have made one some years ago.
    Sep 2005
    1195
    do you use arduino mega 328p and made pcb to db25 ? is there any pcb db25 to arduino kit sold ?
    Sep 2005
    1195
    May 2007
    15
    @ asuratman,
    As far as I know, there are no kits, so you need some knowledge of electronics.
    You have to load GRBL in the Arduino and I used UGS (Universal G-code Sender) but there are more programs.
    I have used an Arduino nano. A parallel port is a connection with 5 input and 12 output ports. there are some schematics of the 6040 layout , google is your friend.
    I made a pcb but maybe it is easier with a board and some wiring, see photos.
    Attachment 477168
    Attachment 477170
    here is a set I made for testing. GRBL software has only 1 connection for speed (PWM) and stop/start spindle. Some where in this forum I have showed the circuits but I cannot find it now.
    Attachment 477172
    Sep 2005
    1195
    I never used arduino, I will check one day. I have the same 2 bob as yours (STV-2) on my cnc routers, very old ... maybe need replacement if my pc dead.
  1. parallel port to usb
    By zcar2043 in forum Machines running Mach Software
    Last Post: 08-18-2016, 03:06 PM
  2. USB to Parallel cable not communicating with CNC machine? Virtual port issues?
    By sportjet in forum CNC Wire Foam Cutter Machines
    Last Post: 11-24-2015, 01:54 PM
  3. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  4. USB to Parallel port??
    By willio in forum Shopmaster/Shoptask
    Last Post: 11-12-2009, 09:42 PM
  5. USB to Parallel port?
    By TheDude in forum Hobbycnc (Products)
    Last Post: 03-24-2008, 05:04 PM
