588,411 active members*
5,396 visitors online*
Results 1 to 7 of 7
    Apr 2013
    65
    Probing in Z?
    We have an Okuma MB-56 that serves as one of our shops work horses. I believe it has an OSP-200M controller, (I'm at home right now I can't check) and a Renishaw work probe. We do not have a manual for the probing system. What we know about it, we learned from dissecting the programs that were installed on the machine when we first got it. We can seem to use the probe in Z a little, but the results never seem to right, and we don't know how to calibrate it in Z to fix it, nor can I figure out how to use it from within an incremental program.
    Here is an example of a set-up program we just started using. I've stubbed in a section towards the end to pick up Z, (perhaps that should be the first thing it picks off) but it is commented out, and I don't know what it should actually look like, it's copied from the one program I have in my (private) library that works in Z (Z must first be set, and the machine in absolute mode to run)
    Code:
    (**INCREMENTAL PROGRAM**)
    (LENGTH OF RAIL)
    VC1=31.1
    (WIDTH OF RAIL)
    VC2=3.9
    (REQ'D PARALLELISM TO X AXIS)
    VC3=.0007
    (OFFSET TO BE SET)
    VC4=1
    IF [VATOL NE 31 ]NOPE
    M130 M127
    G91 G00 X=-[VC1*.4]
    (PROBE Y LEFTSIDE)
    CALL OO10 PMOD=12 PELI=VC2 PIN=.7
    CALL OO20 PHN=50 PY=0
    G00 X=[VC1*.8]
    (PROBE RIGHT SIDE)
    CALL OO20 PHN=49 PY=0
    (TEST)
    IF [ABS[VZOFY[50]-VZOFY[49]] GE VC3]NOUT
    (SET Y)
    VZOFY[VC4]=[VZOFY[50]+VZOFY[49]]/2
    (PROBE X)
    G91 G00 X=-[VC1*.4]
    CALL OO10 PMOD=11 PELI=VC1 PIN=.7
    CALL OO20 PHN=VC4 PX=0
    (PROBE Z)
    (CALL OO10 PMOD=3 PEI=???)
    (CALL OO20 PZ=.2216 PHN=VC4)
    M131
    GOTO NEND
    (ALARMS)
    NOPE
    G90
    VNCOM[1] = 3
    MSG(PROBE NOT IN SPINDLE)
    VDOUT[992]=1
    NOUT
    G90
    VNCOM[1] = 3
    MSG(NOT PARALLEL WITH X AXIS)
    VDOUT[992]=1
    NEND
    G90
    G30 P11
    M2
    Mar 2009
    1982
    find Your "OO10" and "OO20" subroutines
    (PROBE Z)
    this part? You have similar pieces
    (PROBE X)
    G91 G00 X=-[VC1*.4]
    maybe it's reasonable to dig in Probe x part and understand how to transform it to be Z probe
    May 2011
    27
    A valiant effort considering you don't have a manual! If you like this weekend I can scan a "Cliffs notes" version of the probe manual and attach it to an e-mail for you.
    The "PEI" in your Z probe code is the active work Z offset location of the surface you are trying to probe. It usually has the same value as your "PZ" in the following line.
    To calibrate the probe in Z use the following probe sub call:
    Call OO10 PMOD=8 PEI=??? PLI=???
    PEI= Z coordinate value of the gauging face you are using.
    PLI= Apx probe length (TLO)
    Have you considered not using incremental mode? Your probe fixture offsets could use your varables too.
    VZOFY[1]=12.345-VC2/2 etc.
    Apr 2013
    65
    Quote Originally Posted by Maxter View Post
    That would be great, a "cliff notes" version might be better than the original. Okuma's documentation not in the same version of English I speak.
    Oct 2012
    85
    I would like to have that cliff notes of the manual too if it wouldn't be too much trouble. Please and than you.
    Apr 2013
    65
    I normally use absolute when driving the probe, I've got several good programs that loop, and use the probe to set their offsets from a mutiPart fixture, My problems are in probing Z, especially in incremental mode. I'm trying to build a set-up library for our probe, so rather than the operator having to at a minimum set his work offsets approximately, He sets the offset that he need to sets (in the program), he draws a dot on the work piece with a marker, points the probe at it, hit's go,... (and Bob is your Uncle) I'm also currently using common vars in the program to do this, that needs to fixed for forward compatibility.
    Apr 2013
    65
    Cool
    It's taken alot longer than I would have liked to get to test my ideas for this one, caught an opportunity today. Program uses local vars now, a big plus for moving forward, and pings Z... A big time saver.
    Code:
    (LENGTH OF RAIL)
    JV1=28.
    (WIDTH OF RAIL)
    JV2=3.35
    JV3=.0006
    (OFFSET TO BE SET)
    JV4=1
    M130 M127
    G91 G00 X=-[JV1*.4]
    (PROBE Y LEFT SIDE)
    CALL OO10 PMOD=12 PELI=JV2 PIN=.7
    G00 X=[JV1*.8]
    (PROBE RIGHT SIDE)
    (TEST)
    IF [ABS[VZOFY[50]-VZOFY[49]] GE JV3]NOUT
    (SET Y)
    VZOFY[JV4]=[VZOFY[50]+VZOFY[49]]/2
    (PROBE X)
    G91 G00 X=-[JV1*.4]
    CALL OO10 PMOD=11 PELI=JV1 PIN=.7
    CALL OO20 PHN=JV4 PX=0
    VZOFZ[50]=[VAPAZ-VMOFZ-VTOFH[31]] (SET Z OFFSET 50 TO CURRENT POS)
    G15 H50
    G90 G00 G56 H31 Z0.
    (PROBE Z)
    CALL OO10 PMOD=3 PEI=-.2
    CALL OO20 PHN=JV4 PZ=0.2209 (PZ WAS .2663)
    GOTO NEND
    (ALARMS)
    NOPE
    G90
    G15 H=JV4
    M131
    VNCOM[1] = 3
    VDOUT[992]=1
    NOUT
    G90
    G15 H=JV4
    M131
    VNCOM[1] = 3
    VDOUT[992]=1
    NEND
    G90
    G15 H=JV4
    M131
    M2
    It's not been thoroughly tested, but it does seem to work. I'm still looking for a better way to probe Z in incremental mode, thats quite the work around, (and I do enter absolute mode to pull it off) any thoughts on improvements would be great as well. That said, if you have a machine/probe that can run this program, and you make long skinny parts with their origins in the center top, enjoy.
  1. Probing the 4th
    By Kool Parts in forum Haas Mills
    Last Post: 04-26-2013, 12:40 AM
  2. probing help
    By ozzie34231 in forum SmoothStepper Motion Control
    Last Post: 07-29-2012, 06:15 PM
  3. Probing in a TM-1P
    By HayreAss in forum Haas Mills
    Last Post: 01-15-2012, 02:32 AM
  4. Probing?
    By chunkymonkey in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2008, 05:39 AM
