That's the model 4000 lathe, the shorter of the two models.
I see it has the AC motor,smaller speed controller box, single-speed pulley set, shorter crosslide, non-rocker toolpost, and the earlier style tailstock.
I think that it's a custom CNC conversion, made before Sherline offered their own CNC-ready machines, so, like my D&M-converted Sherline mill, it has the standard leadscrews with no thrust bearings.
Great little lathe, especially with the milling attachment!
I think EVERYONE should start with manual machines, and get a feel for cutting capabilities and performance, as well as dealing with things like backlash and deflection. Too often I've seen new guys jump right into machining with CNC, and then start blaming the machine, the tooling, and the material for every problem...
What tooling do you have?
How many wires are coming out of those steppers?
For power feed, you might want to look at buying a stepper driver for a single axis, like the Gecko drives... although, if you're buying a driver and power supply, it's a short step to buy one for the other axis at the same time.
Mach3 in demo mode will work as a power feed, as will the Linux-based EMC.
I messed around with Mach for a few years before I made the switch to the excellent, and free, EMC.
Oh yeah, welcome to the forum!
http://www.youtube.com/user/vlmarshall
