588,058 active members*
5,093 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > How large end mills can be used on a Taig?
Results 1 to 8 of 8
    May 2006
    309
    I need to order some end mills for my Taig mill and need to know how thick these can be before they make problems for a small machine like this? I want to work with metals like aluminium, cupper, brass and steel.
    Aug 2006
    231
    The Er 16 collet holds up to 3/8" shank
    May 2006
    309
    Do you mean I can use a 3/8 end mill on harder metal with my machine?
    Aug 2006
    231
    3/8 end mill
    Quote Originally Posted by jaru-eri View Post
    All I can say is that it will fit a 3/8" shank in the collet. I have used a 3/8 end mill on aluminim and softer so I cannot comment on harder materials. Maybe someone else will jump in with more exp to that
    Aug 2006
    161
    Ive used 8mm Endmills on Steel, Ali, Brass and wood on my Taig, but then I don't have the original spindle, so can't comment on how it would hold up, but the machine itself had no problems going through 4mm thick steel but in small increments obviously
    DJH
    May 2007
    125
    I have used 1/4" end mills on stainless steel with mine.
    Jan 2007
    634
    You can also use up to 1/2" mills with the use of an endmill holder that goes on the spindles external threads (replaces the collet nut). Quite useful to be able to use the 1/2" mills for some things, though there is obviously little chance you will have much luck pushing one of that size through any tough materials. 3/8" and 1/4" works fine for those though.
    Oct 2005
    61
    Talking
    I have been using tool holders made from the Taig blank arbors.
    The 3/4" end mill will cut plastics as fast as you could ever want,
    aluminum at slow to moderate feeds but I usually use it for surfacing.
    My favorite tool is a 1/4" 3 flute carbide running at 10000 RPM in aluminum
    That is where this mill really shines.
    Metal_byter
    http://microtools.ca
  1. Ball screws for Taig mills. Anyone?
    By Idle hands in forum Taig Mills / Lathes
    Last Post: 12-26-2009, 11:55 PM
  2. Taig mills
    By ddgman2001 in forum Taig Mills / Lathes
    Last Post: 01-25-2007, 06:52 PM
  3. Taig mini mills
    By gizmo in forum Taig Mills / Lathes
    Last Post: 08-09-2006, 04:23 AM
  4. How large steppers do I need on a Taig mill??
    By jaru-eri in forum Taig Mills / Lathes
    Last Post: 07-29-2006, 01:34 PM
  5. large diameter end mills??
    By jlembas in forum MetalWork Discussion
    Last Post: 06-08-2006, 03:12 AM
