587,935 active members*
4,260 visitors online*
Results 1 to 8 of 8
    Jun 2003
    2103
    Only 16 colors?????
    I have a problem with a new mother board not wanting to used my
    graphics card, older, but worked great with the old mother board. I
    have removed the card and set the bios for the on board video but I
    only get 16 colors and a max screen size of 840 X 680 or something like
    that. I use Mach2 and can't get the Mach2 screen set using that size to load.
    How do you change the color number, or can you?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    You might have to install drivers for te onboard video.
    Jun 2003
    2103
    Ger21 I already tried and ended up taking it to the pc shop.The only drivers for video I could find was for the AGP slot and card. It did not work at all.
    Thanks for the help.
    Mike
    May 2003
    550
    What Motherboard and OS?
    Apr 2003
    1079
    If you do not know the make of board, or cannot find the numbers pronted on the board somewhere, let us know the make of the bios please. There may be some programs to use to determine the board name.
    Feb 2004
    2337
    I take it you are not a XP user. XP should do a reasonable job of finding a driver for your video card.
    Also, does your Mother board have onboard video? If it does there could be some confilct between that and the video card.
    Being outside the square !!!
    Mar 2004
    60
    It is definitely a driver issue. If your new motherboard came with a CD sometimes the drivers are buried deep in a file tree. Some operating systems are lazy in finding the appropriate drivers automatically. Go to device manager and reinstall video driver, you will need to search the directories until the right file shows up on the file name text box. Assuming you are using Windows ME or earlier? Also there are hundreds of sites that have old and new third party drivers. Give us more info on the motherboard.
    Jun 2003
    2103
    Benny I are a xp user but it did not find the file on the cd. All is well though I took it to the pc dr that I had called for instructions on how to fix it. He told me how he did it and it had done the exact same thing except when windows rebooted it did not take the file. Anyway it si fixed and the machine is running.
    Mike
    edited: you see all the mispelled words.........it's gonn get worse. I found out yesterday I have a lower back disc that is either calcified or gone.....or maybe scar tissue from an old surgery. Pain tablets and muscle relaxers don't help you spelling. I had to retype this edit three times. :violin:
  1. CNC Painter Development Update
    By vacpress in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 07-13-2007, 03:06 AM
  2. Thanks
    By Boss302 in forum OneCNC
    Last Post: 07-21-2004, 04:51 PM
