Hi All,
sometimes when i'm trying to cut some MDF board on my router using mach 3 the Z axis going too deep while cutting, when at mach 3 screen showing it's cutting at 2 mm depth but on the board it starts at 2mm and end about 5 or 6 mm, the G code generated by Vectric aspire ,
i attached i pic showing how it cutting , does anyone had this issue before??
(my driver is G540 with Nema 23 steppers)
usually when this happens i close mach 3 and cut the board again using the same G code file and it works well
Regards
haz
