588,235 active members*
4,314 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 303SS loads/feeds/etc - tiny cutters
Results 1 to 6 of 6
    Apr 2005
    345
    I have a SS job to quote - making some pallet branding stamps. I am recommending 303 to the customer to make it machinable as there is some very detailed machining that will require a ~0.030 end mill to machine some raised letters.
    So, with minimum experience with cutters this small....what would be a good starting point for a 1/32 cutter in 303 on a retrofitted BOSS with max ~4000rpm?
    Chip load, DOC, SFM, cutter material........any input appreciated to give me a little confidence in the cycle time my CAM is telling me.......
    Scott
    http://www.scpconcepts.com
    Jul 2006
    103
    good luck to ya!
    better keep your chip load small and lots "o" lubricity.
    no help here, let us know how it works out.
    Apr 2005
    345
    Well, got some material coming.......kind of scary, wish I could do it in aluminum. Even scarier - lookin through McMaster I see 0.005" diameter cutters! Are you kidding me?
    Oct 2005
    251
    I would suggest HSS to start. SF around 50. Feed about .0005 per flute. The DOC should be 25-30 percent of diameter axial and radial. 4000 RPM and 8 IPM for a 4 flute tool. I suggest HSS because of cost, flexability and your machine can't make the RPM to run carbide the proper SFM. Use a good tool that is very sharp and flood it with coolant to move the chips away. Recutting will kill that small tool. The feedrate is modest and you may find it possible to run faster.
    Apr 2005
    345
    I would actually be pretty happy to get 8ipm and ~.010 depth. We will see..........
    Oct 2006
    586
    well i just Quoted some parts that im going to have to use the same size endmill but i got lucky its 6061 alum. but i would say for you just dont get in to big a hurry broke tools cost to much,
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
