587,684 active members*
3,206 visitors online*
    May 2006
    35
    small tapered slots
    I have to m/c appox. 50 small slots with a .010 taper on the sides the slots are only .065 to .085 wide and .250 long. Any ideas on the best way to m/c these .We have thougth of may be sparking or wire cutting ? Any other ideas would be good
    May 2006
    35
    small slots
    I forgot to say the mat. is s/s304 and .186 thick
    Oct 2006
    586
    Quote Originally Posted by barnesy View Post
    Well if you mill them you will have to use an endmill that is about .02 smaller than the slot its self make your first cut them come back and taper each side the desired amount
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Jan 2006
    4396
    Depending on how long the slots are Wire EDM is the best way to do this. 304SS will work harden if an end mill dulls too much in the cut. If it is short you could have these Laser cut too.
    Good luck with what you decide.
    Cheers!!!!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  1. T slots in MDF??
    By JerryFlyGuy in forum DIY CNC Router Table Machines
    Last Post: 03-11-2007, 05:30 AM
  2. Machined T-Slots?
    By SpookyDad in forum DIY CNC Router Table Machines
    Last Post: 07-17-2006, 02:37 AM
  3. Machine for making slots in SS tubing
    By ngr1 in forum MetalWork Discussion
    Last Post: 06-23-2006, 07:00 PM
  4. T-slots 4x8 - One side done
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 06-08-2004, 04:47 AM
  5. Need help with T-Slots - Boring holes
    Last Post: 04-11-2004, 04:39 AM
