588,666 active members*
6,568 visitors online*
Page 1 of 4 123
Results 1 to 20 of 67
    May 2007
    60
    Easy Build 800 x 500 x 85
    Ok it’s my turn now and all know the drill, long time reader first time poster blah blah blah.
    My background is fitting and machining I have worked on various CNC machines including center lathes, turret mills, machining centers, wire cutter and of course a router and I currently work as a contract draftsman.
    5 years ago I decided to convert my lathe/mill to CNC and did so on a very tight budget, this clouded my judgement and I made a poor motor selection. In order to break through the friction of the machines slides I had to run a reduction that saw the machine having a top speed of 200mm/minute. I found it extremely slow and frustrating and proceeded to shelve the idea.
    So a few years passed by and I decided that I had a perfectly good driver setup and motors going to waist when really all I needed to do was use them on a machine with less friction and lighter cutting loads. I looked at a wire cutters and sink edm’s but didn’t think they would be useful in most of what I do or would like to do.
    That's when the router idea came up, I found CNC Zone and started putting ideas together. I looked at simple designs for a first machine eg. jgro and made 3d models of my own concepts which led to more complicated designs that would require manufacture on a CNC. I have been going round and round in circles and have completed several models but achieved nothing.
    So I decided to get serious, make some firm decisions and finally make it happen. I put together a model that was easy to build at home with hand tools and my lathe/mill. I bought some materials and prepared to start my build. However my timing couldn’t be worse as I am in the middle of renovating my house (another long drawn out project but I won’t bore you with that one) and I have very little spare time on the weekends. Deciding nothing can stop me now I decided to build it on week nights. So this project will be a slow one I feel it will take 10-12 weeks of 1-2 hours 5 nights a week.
    The machine:
    Controller – Laptop running XP and Mach 3
    Driver – Hobby CNC 4 Axis board (Purchased 5 years ago so different to their current board which intend to upgrade to at a later date to increase my top speed)
    Motors – 3 x Unipolar 127 once/inch NEMA 23
    Router – Working area 800mm x 500mm x 85mm, Timber construction, Skate bearing slides, threaded rod lead screws.
    The model is 99% complete I need to extend the table 50mm add a few fasteners and limit switches but everything else is complete. I have completed drawings for the z-axis and started machining some of the parts. I have attached pictures of the model (Later I will add an E-Drawing if anyone is interested) and photos of my driver setup. I endeavour to update my log weekly and include photos. I hope my log is interesting and helps others to embark on this truly enlightening hobby.
    Attached Thumbnails Attached Thumbnails front isometric view.jpg   rear isometric view.jpg   bottom isometric view.jpg   driver box and motor.jpg
    If it can't be fixed with a hammer it must be an electrical problem!
    May 2007
    60
    I have started making parts so far I have turned up the z axis lead screw the acetal lead nut and milled the z axis bearing mounts. I will be building the z axis assembly first to check that my design works well then I will build the rest of the parts in full batches.
    Attached Thumbnails Attached Thumbnails z axis bearing mount.JPG   z axis bearing assembly.JPG
    Aug 2008
    28
    Hey Daniel233,
    welcome to the forum
    nice looking machine, I'll be following your progress!
    Have you considered using 2 leadscrews for your x-axis? You already have a 4-axis controller, and it could increase the stabiltity. I would keep this option open just in case.
    good luck with your build from another "newbie" on the forum.
    greets,
    Jeroen
    May 2007
    60
    Hi jeroen87,
    Thanks for your support. Yes I have considered running a double lead screw x-axis but as I plan to replace my driver board and upsize the motors I don't want to spend any time or money on them. I am going to build it and see if it will be acceptable without it at this stage but if it is needed I plan to slave the 2nd lead screw off the first with a toothed belt.
    Cheers
    Apr 2007
    1955
    Nice start on the project.
    You are right about the driver and motor - a bit undersized, but sufficient for learning.
    Do you have an idea / goal for the spindle motor and running speed desired ? I am thinking that your setup would be ideal for a circuit board router or perhaps routing pictures into wood - is your thinking something like this ?
    May 2007
    60
    Hi harryn
    I am hoping to be able to push a 5mm or 6mm cutter through timber, plywood and mdf in order to make identical parts for a more serious 2nd machine. I intend to do so in multiple smaller cuts of a size the machine will be capable of.
    Cheers
    May 2007
    60
    Tonight I added the holes and slots to finish off the z-axis lead nut. I assembled it on the lead screw with a circlip for pre-tension to prevent backlash and it works perfectly.
    Attached Thumbnails Attached Thumbnails z axis lead screw.JPG   lead nut.JPG   z axis lead screw assembly.JPG
    May 2007
    60
    Today I purchased the timber for the z-axis and y-axis frames, I routed the chamfers on the z-axis and y-axis boards that support the angle rails. I cut must of the plates for the 2 axis’s and completed the z-axis side plates.
    Attached Thumbnails Attached Thumbnails z axis side plate.JPG   z axis side plate assembly.JPG
    May 2007
    60
    Today I made some more parts for the z-axis. It was a bit fiddly to get the right width on the front and rear plates so the slide would move freely, I think the other axis's will be better as the side plates are longer and will accommodate more flexing.
    Attached Thumbnails Attached Thumbnails z axis rear plate.JPG   z axis front plate.JPG   z axis partially assembled.JPG
    May 2007
    60
    I finished the plates for the y-axis last night. My next move is to make the motor and lead screw support plates for the z-axis and then I will be able to hook the z-axis up to the computer and see how well it works.
    Attached Thumbnails Attached Thumbnails y axis front plate.JPG   y axis rear plate.JPG   y axis side plate.JPG   lead nut mount.JPG
    Dec 2004
    1865
    Quote Originally Posted by Daniel233 View Post
    The machine:
    A couple of things come to mind in no particular order.
    1.The motors and drives sound awfully small for this machine also.
    2. Laptops and Mach3 thru the pport don't mix.
    3.What you need is the special hammer that I recently made. It works well on both machines and the operators.
    4. If you designed the mechanicals incorrectly, it must be a controls problem!!!:withstupi
    5. You will be supprised at how fast you have to go in wood so as not to burn up the bits.
    Good luck.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    May 2007
    60
    Hi Mike,
    Yeah I know the motors are on the smallish side I am just hoping they will be usable. I have assembled the complete z-axis and the motors are capable of driving it at 300mm per minute and I can’t stall the carriage by hand. Whilst I know this is a slow feed rate for timber I am hoping that by slowing the router speed down to around 10000rpm and taking a 0.5mm finishing cut I will still achieve reasonable results without burning the timber. I have also come across reports from people using PP ports on laptops having problems but I have Mach 3 up and running driving the motors without any problems, I must be one of the lucky ones.
    Cheers
    Dec 2004
    1865
    Hi Mike,
    Cheers
    The more I read the more I learn.
    Although laptops are not supported by Mach3 anymore, as they were a majority of support requests, there are a bunch of people running them.
    I guess if it works for you , great.
    It also tends to be hardware specific as some will run it and some won't.
    300mm/m = 11.?IPM. I would guess that 1000mm/m (40IPM) would be more apropriate for wood cutting, but I haven't cut much wood on my router, YET. I mostly do fiberglass and CF. At this point you don't have anything to lose. Try it and see how it works. You already have nema 23 mounts, so upgrading to larger/faster motors would be easy.
    Better electronics are just a charge card away.
    I will keep watching.
    Mike
    May 2007
    60
    I finished the parts to complete the z-axis and assembled it.
    Attached Thumbnails Attached Thumbnails lower lead screw support plate.JPG   upper lead screw support plate.JPG   motor mount plate.JPG   z axis assembled.JPG
    May 2007
    60
    I clamped a piece of pine against the y-axis frame and attached the router to the z-axis plate with electrical cable ties and supported it each side with clamped boards. It wasn't completely ridged but fine to test it. I took a 50mm long cut at 30000rpm and 300mm/min (my max is 350mm/min). Results appear good considering the lack of rigidity.
    Attached Thumbnails Attached Thumbnails test cut side 1.JPG   test cut side 2.JPG
    Attached Files Attached Files
    Dec 2004
    1865
    Looks good to me.
    Nice video.
    How many flutes on the cutter?
    May 2007
    60
    Thanks Mike,
    It is just a cheap double straight fluted cemented carbide 1/4". The cutter is not actually that good I used it in case something went wrong. I intend to use double fluted solid carbide cutters when the machine is finished. I envisage using a 6mm depth of cut and leaving a finishing allowance of 0.5mm (top and sides), hopefully this will give good cutter life and good surface finish.
    Cheers
    Dec 2004
    1865
    I like your signature.
    What we get at work is, "I designed it wrong, so it must be a controls problem"
    Mike
    May 2007
    60
    Firstly I must admit to stealing my signature from another forum.
    Last night I found that the combination of the lead screw being loose in the bearing and the bearing being loose in the mount was causing my lead screw to run out. I turned the inside nuts to a 120 degree included angle and ran 2 layers of masking tape around the bearings and it runs true now.
    Cheers
    Attached Thumbnails Attached Thumbnails lock nut 1.jpg   lock nut 2.jpg   lock nut assembly.jpg
    Dec 2004
    1865
    Cheers
    At least you found and fixed it.
    What you did is make sure that only the inner race is being grabbed and that the bearing doesn't move on the shaft.
    Nice job on turning the nuts.
Page 1 of 4 123
  1. Easy to build torsion box and rails
    By lgroulx200 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2012, 06:37 PM
  2. Easy to build CNC Mill Stepper Motor and Driver circuit
    By Tom McWire in forum Open Source Controller Boards
    Last Post: 03-31-2010, 04:09 PM
  3. MastercamX not so easy with easy projects
    By X7racer in forum Mastercam
    Last Post: 05-22-2008, 03:28 AM
  4. Easy CNC and Easy Stepp'n
    By kylecroft in forum Community Club House
    Last Post: 02-18-2007, 06:54 PM
