Originally Posted by
harryn
Interestingly, both the V rails and the profile rail use similar concepts. The shape of the contact area is actually pretty similar, the ball bearing designs just have many more contact points to spread out the load. You can exactly see this in the vendor ratings, if one carriage is not enough, add another and it doubles the rating. Similarly, V bearings are rated "per bearing".
Profile rail itself is actually surprisingly flexible and depends 100% on how it is mounted. The same is true of the V rail.
IMHO, the biggest challenge is not finding a rail and frame combination that are stiff enough, it is aligning two of them to each other so that they don't wear each other out during use. In a professional, high volume shop this is designed in, but at home, it is a critical point.
My suggestion is to try hard to use a single large rail and block rather than two rails in parallel, when practical. If you need more capacity, add another block rather than another rail. This isn't always possible.
I have some of the skate bearing setups and they work, but the value of having a ground, hardened rail becomes obvious pretty fast.
