588,504 active members*
4,916 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Nov 2007
    11
    machining 1018 steel
    most of my experience has been with machining aluminum which obviously has a very big window for acceptible feeds and speeds. i just got a job to machine some steel plate, .25 and .5 thick. i will be doing this on my haas vf-2 vmc. i have an additional coolant pump which flows like a garden hose too. i will have to machine out some 2-3" dia circles and do some profiling. my question is what would be a good end mill to use out of the msc catalog, i usually use 3/8 or 1/2 diameter. i have used carbide in the past but as soon as it cuts a chip it chips the tool so i was thinking of using cobalt (coated?)even if i have to go through a few. the important thing is that i make it through this job and im not concerned about macining fast just accurate with a decent finish.
    with the selected tool what would be a good axial depth of cut, ipm feed ,rpm and plunge feed.should i ruff and finish or just use 1 tool to do it? i really need the experienced help here guys, im a metal fabricator with a cnc and have done pretty well but the steel has gave me fits in the past
    Jul 2004
    601
    Well start with a decent carbide endmill. I'd go for a Hanita vari flute. I run my 1/2" at 600sfm (4500 rpm) and about 37ipm (.002/tooth). I slot at .1 deep, and side mill at .2 deep (50% engagement) The tool will do a clean up pass at 1.0 deep and not sing. This is all done on a TM-1, so you should be able to go with a deeper cut and higher chip load on a vf-2. I've never had any issues chipping the mill if I recut a chip.
    Good Luck.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Jul 2005
    12177
    Forget the coolant. Go with a TiAlN coated mill and use an airblast for cooling and chip removal. You can run the sfm DSL PWR suggests but if you use a 5/8" 5 flute cutter you can up the feed and take your full 0.5" thickness in one cut.
    You mention circles, do you mean holes? How are you programming this CAM or hand?
    Oct 2005
    672
    Quote Originally Posted by Geof View Post
    Someone is itchin' to show off his newly acquired knowledge.
    Jul 2005
    12177
    Quote Originally Posted by Caprirs View Post
    Is this a dig because you know I have mastercam in the company now?
    Actually I was going to suggest the Haas G13 circular pocket routine.
    Dec 2006
    242
    If I ran a 5/8" 5 flute slotting in 1/2" material it would sing and probably break unless it was a V carb. A variable helix TiALN coated endmil is definitely the tool for the job. I get great tool life at 400 SFM (3000 rpm for 1/2" endmill). DRY DRY DRY. Turn the coolant on, cut your tool life in half. No CAM system needed. Just a starter hole and then G3 two passes. With the starter hole already done, you can cut a 3" hole in 1/2" thick 1018 in 30 seconds. 3000 rpm, .0025" feed per tooth for the rough pass, then 4000 rpm, .002" fpt for the finish pass. This requires a stub length holder. I would not run a holder with a projection length any longer than 1.75 I prefer the new ones with 1.375" length. A lot of guys on here don't get the difference and try to get the same results with 2.5" or even 4" length holders.
    Oct 2005
    672
    Not the Mastercam. The GeofCAM. You are one of the converted now per your thread .
    I just wish my mills were rigid enough to do that sort of cutting.
    Dec 2006
    242
    What machine are you running? An alternative would be a 3/8" varimill taking 1/4" depth, 2 passes and 1 finish pass and you're still under a minute.
    Jul 2005
    12177
    .. The GeofCAM. ....
    I had forgotten that.
    Jun 2009
    8
    sorry guys, i wasnt ignoring you. for some reason i couldnt post after initially starting this thread. i tried to get through to the administrator several times with no luck and finally just reregistered under a different name. busted bit is now busted blade. anyway thanks for the feed back.
    i am set up for coolant so i guess ill try that. my problem has been that i have not been machining aggresively enough and thats why i have junked cutters in the past when trying to machine steel.im self tought and sometimes that hurts me. i think the hanita varimill? might work for me. i am using bobcad.
    so i definetly need a starter hole? no plunging?
    Dec 2006
    242
    Plunging
    You can plunge, but with a 3/8" or 1/2" four flute endmill, I get chatter if I go above 800 rpm and .00025" per tooth, so that's a brisk 0.8 inches per minute. Center cutting does not make it a drill. Even a basic 1/2" HSS drill can go 450 rpm and .01" feed per tooth for a feedrate of 4.5 inches per minute. Then you just fast feed or even rapid into the hole with the varimill. Air blast when it first starts milling after you've plunged into the hole is much more important than after it has gone even an inch or two across. There is no where for the chips to be thrown, so they need to be blown out. Chip recutting is hard on any endmill. Deadly with other materials. You'll know it when you hear it. Dry though!
    Jun 2009
    8
    thanks Dave. the starter hole's a no brainer
    Jun 2009
    8
    just wanted to say thanks guys for your help. the job is going well and i'm happy.ended up using coated 4flute hanita varimill, 3/8x1/2loc w/chamfer,500sfm, .002chip, 5100rpm,41ipm,full slot .135deep (hanita said i can go 1 dia), flooding, cant even hear the .003 finish pass and its barely working the machine. spitting out nice mirror polished chips. i never thought you could machine steel like that. might actually make good money on this job. thanks again:banana:
    Dec 2006
    242
    I dare you to turn the coolant off. Double the tool life. No one is a believer until they are.
    Jun 2009
    8
    im not scared. i swear . but i am not set up with an air blast. i beleive you. hanita didnt seem to frown upon it (sell more bits, right?). the job is not a long run fortunatley. does it have to do with thermal issues?
    Jul 2005
    12177
    Quote Originally Posted by busted blade View Post
    .... does it have to do with thermal issues?
    Yes, carbide doesn't like to get hot and then quenched; you can get thermal fractures in the cutting edge which lead to premature failure. Another issue with coolant rather than air is that sometimes you cannot clear the chips as effectively so you get re-cutting which can result in chipping the tool.
    Having said that I will mention that sometimes if you are really flooding the coolant you can get very good tool life which I attribute to keeping the tool cool all the time because it is running well submerged.
    On the stuff I do personally, which is fixtures and prototypes I flip flop between using coolant and running at a modest rate and running dry and really ripping stuff off. My experience is that you have to get things correctly sorted out to run dry and if you don't things can go downhill quickly; running with coolant can be more forgiving.
    Jun 2009
    8
    my auxilary coolant pump (which im using) is like a garden hose. no evidence of heat at all,like i said chips have a mirror finish on the sheared side and a sandblasted grey finish on the other and is .009+_ thk. almost looks like aluminum. im sure there has to be heat somewhere however small. we'll see
    Dec 2006
    242
    Getting longer tool life from dry milling happens specifically with one coating: TiALN. A chemist could explain it better, but when you reach a critical temperature at the cutting edge, a layer of aluminum oxide is formed that protects the tool's cutting edge. If you flood cool, this oxidation layer is never formed, and you just get normal life. From what I've read, I don't think even half the guys on here have honestly tried this method.
    http://www.mmsonline.com/articles/wh...kes-sense.aspx
    http://www.ctemag.com/dynamic.articles.php?id=94
    Jun 2009
    8
    im wondering if breaking the tool in dry would form the appropriate surface conditioning then go ahead and use the coolant for chip evacuation? if i had a big compressor i would do it dry. i did see the coating begin to degrade after a fairly short period. primarily in the flute where the chip is rubbing. probably at the cutting edge too just not as oblvious
    Dec 2006
    242
    Excellent question. I don't know. What depth are you cutting? Slotting one diameter deep doesn't REQUIRE an air blast after the first couple of inches, it's just a good idea. I did once have a job that required about 200 slots in 1018 steel, 3/8" wide, 1" deep and 7" long. Chip recutting was a major problem with that job after the first 1/2" in depth. I tried clamping an airline near the cutter and I tried coolant. I think for the final depth I went with coolant, but for 3 diameters deep, it's just a tough job and I always heard some recutting in the last 1/4" of depth.
Page 1 of 2 12
  1. 1018 Steel vs 6061 Aluminum
    By trmpyro in forum DIY CNC Router Table Machines
    Last Post: 01-30-2009, 03:21 PM
  2. machining steel
    By fourperf in forum Uncategorised MetalWorking Machines
    Last Post: 09-26-2008, 08:20 AM
  3. Machining A2 steel
    By g30u0w0 in forum MetalWork Discussion
    Last Post: 01-17-2008, 03:40 AM
  4. Machining steel
    By JOM in forum MadCAM
    Last Post: 08-31-2006, 01:07 AM
  5. ACME - 1018 steel or heat treat 4140 alloy
    By CnC_BoY in forum Linear and Rotary Motion
    Last Post: 03-21-2006, 11:41 PM
