Rubber seals generate heat, and if the heat cannot dissipate quickly enough, it will build up.
A shielded bearing will run cooler, because it does not actually make firm contact with the inner race. But, it is not a dust/moisture proof either.
If you have one side of the bearing closed within a housing, then you might remove the seal on that side, to decrease friction somewhat.
Machine spindles and high speed electric motors do not have contact seals. Instead, they use a baffle system to keep the grease in and the dirt out. The baffle is called a labyrinth seal system, which is not something you buy, but something you build. A labyrinth is a pair of disks with interpositioned grooves, creating a "square wave" path which the grease/dirt/air must pass through. But the one disk is fastened to the rotating member and the opposing disk is part of the housing. They run close together, maybe .010" apart.
