588,616 active members*
4,729 visitors online*
    Apr 2011
    New Romaxx Just Arrived!!!!
    Delivered today and a big weekend planned!
    Apr 2005
    438
    You are going to have fun.
    The HS1 is a great desktop cnc router, I bought mine a little over 2 years ago and the only problems I have had are the ones caused by the guy at the keyboard.
    Tips, put a dust shoe on it of some type, and the DIY auto Z tool you can find posts on the zone about is a time saver. If you are using Ron's Mach3 screen set you already have the scripts for it installed.
    Apr 2011
    Quote Originally Posted by lovebugjunkie View Post
    As a newby, you have exceeded my understanding ;-P
    I am assuming that the auto Z tool helps in setting the Z height or zero? Also that you install it as a script into the BobCAD toolpath or the generated code?
    Thanks for you advice and support (in advance).
    Garry
    Apr 2005
    438
    Correct on the use of the auto Z tool.
    The auto z height tool is a script that runs within Mach3. If you are running Mach3 download the Mach3 screen set on Ron's site. Once you run Mach3 using his screen set the script is already available and he also put two buttons on the Main Mach3 screen for auto z and also x,y.
    I have not made a tool that I am happy with as a x,y tool, my Z tool is only a piece of scrap aluminum I had laying around. Come in handy when you have to change bits in a job for any reason.
  1. Romaxx
    By lovebugjunkie in forum Commercial CNC Wood Routers
    Last Post: 08-24-2022, 03:45 AM
  2. Looking for Romaxx WD1--Used??
    By jascamera in forum Commercial CNC Wood Routers
    Last Post: 02-13-2012, 11:55 PM
  3. Any So. Cal Romaxx CNC owners out there?
    By mjhjenks in forum Commercial CNC Wood Routers
    Last Post: 05-27-2011, 11:04 PM
  4. Best bench for a Romaxx WD-1?
    By mochaman in forum Commercial CNC Wood Routers
    Last Post: 09-19-2010, 07:07 AM
  5. My Romaxx HS-1 Arrived
    By mattgatten in forum Commercial CNC Wood Routers
    Last Post: 02-12-2009, 03:37 PM
