For those with CNC routers... Quote needed to profile an MDF solid to desired shape (provided). This is to be used as a pattern.
File types available - STL, if you need a different type it shouldn't be a problem.
Will need to cut from 400mm x 415mm x 85mm mdf layered as a solid.
those interested pm or post and i will forward a STL, if another file type is needed please state it.
