588,487 active members*
5,988 visitors online*
    Jul 2004
    79
    coolant system
    I want to add a mist coolant system to both of my knee mills. I've noticed there are several different brands and types. There are also many different types of coolants and cutting fluids.
    What mist coolant systems work best, and which coolants/cutting fluids should I use?
    I cut a wide range of materials, from plastics to steel. The majority of my work is aluminum.
    Brian
    Feb 2005
    44
    We use Hangsterfers CF-500. Its good and doesn't give people rashs like some other crap we used. Its Pricey, and it smells bad after a while.
  1. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  2. How to avoid stinkin' coolant?
    By ESjaavik in forum DNC Problems and Solutions
    Last Post: 10-11-2005, 12:47 AM
  3. Pics of my RF45 clone cnc conversion with flood coolant
    By CNCPlastic in forum Knee Vertical Mills
    Last Post: 01-26-2005, 09:02 PM
  4. Need suggestions on components 5 axis control system?
    By pab in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2005, 11:34 PM
  5. Cheap coolant system
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2004, 08:03 PM
