588,684 active members*
6,139 visitors online*
Results 1 to 6 of 6
    Apr 2008
    5
    Carbide insert designations
    I've searched the web with no definitive answer on this. I was wondering if there is a standard to letter designators for carbide inserts? For instance I have a Dolfa 2" - 3 insert face mill that uses SPC, SPG, or SPU42 inserts. Is there any rhyme or reason to the letters used here?
    Jan 2007
    210
    S = square
    P = 11 degree side clearance ( sometimes 10 degrees )
    C = +/-.0005 IC (size of the square), +/-.001 Thickness
    ..... G = +/- .001 IC, +/-.005 Thickness
    ......U = +/- .005 IC, +/-.005 Thickness, unground periphery - not recommended for milling
    4 = .500 IC dim (Inscribed circle in 1/8ths of an inch)
    2 = .125 Thick ( Thickness in 1/16ths of an inch)
    You are missing the last number which specifies the radius size in 64ths. #1=.0156 rad, #2=.0312 rad. etc.
    This is an ANSI standard designation and is found in all the mfgs catalogs.
    I believe CarbideDepot also has this on their website.
    Bob
    You can always spot the pioneers -- They're the ones with the arrows in their backs.
    Apr 2005
    3634
    T= Triangle
    I had a chart for Iscar Inserts at work, maybe they have a chart on line?
    Free DXF - vectorink.com
    Apr 2008
    5
    Thanks a bunch. Thats just the kind of info I was looking for!
    Mike
    Jul 2006
    1062
    I've had this for a while...May be helpful?
    Attached Files Attached Files
    Keith
    Jan 2004
    3154
    I didn't look at the above zip but here is a link http://www.kbctools.com/can/Navigati...fm?PDFPage=247
    www.integratedmechanical.ca
  1. Tool Insert Help
    By Cartierusm in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2007, 03:05 PM
  2. Looking for Insert.
    By Al_The_Man in forum MetalWork Discussion
    Last Post: 08-02-2007, 04:27 PM
  3. Insert for 62 Hrc
    By M-man in forum MetalWork Discussion
    Last Post: 02-13-2007, 10:09 PM
  4. INsert Molding
    By PC7 in forum Moldmaking
    Last Post: 04-15-2006, 12:56 PM
  5. Identify this insert
    By Cold Fusion in forum MetalWork Discussion
    Last Post: 08-28-2005, 03:56 AM
