From Mesa's product description,
'The 7I37 provides 8 Isolated 48VDC 1A output drivers. All output drivers are low saturation voltage...'
The boards look like they only recieve 5v from your PC via the 5i20 50 pin ribbon (unless optionally configured for 5v external at board).
How do they end up with 48Vdc output? Or does this signify the capacity, 0-48V input (similar to load on a traditional mechanical relay)? Sorry, not that familiar with MOSFET outputs, everything but. What is the proper way to use these, wiring to the + and - terminal of the output? positive power in at negative terminal and controlled output from + terminal to field device?
Thanks in advance
