587,645 active members*
3,239 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang GT VFD 2.2kw how connect between NOVUSUN NVEM v2
    Dec 2020
    4
    Hello everyone, please help me. I have connected VFD GT 2.2kw between NOVUSUN NVEM v2 + mach 3 controller.
    But I am having a problem I cannot adjust the spindle speed for match3. When enabled through match 3, the speed increases to the maximum. Help how to connect correctly
    15362
    Re: Huanyang GT VFD 2.2kw how connect between NOVUSUN NVEM v2
    Quote Originally Posted by Mujicok View Post
    First you have to see if the 0-10v Analog is working from the Novusun output you can test this in MDI M3S6000 and check the output voltage with a meter, use different RPM settings to see if the voltage changes 12000 should be around 5v one yyou have this part working then you can move to the VFD Drive
    Mactec54
    Dec 2020
    4
    thank you very much for your respond. I appreciate, you are the only who responded to my request. I just started CNC working. Could you please send me a photo how to connect NOVUSUN NVEM v2 with VFD GT . I ve been trying to find any info in internet about VFD GT connecting. I m a Russian speaker and it gets the job more difficult. MDI M3S6000 What is this, could you explain please.
  1. Help with Novusun NVEM control card
    By RODCNC1147 in forum Controller Cards
    Last Post: 02-22-2024, 11:59 AM
  2. NVEM V2 connect to AC SERVO DRIVER AASD-15A-V6.3
    By Josip_Skukan in forum Spindles / VFD
    Last Post: 08-01-2020, 08:00 PM
  3. Replies: 0
    Last Post: 02-26-2020, 07:49 PM
  4. Help with Novusun NVEM control card
    By prapto in forum Uncategorised CAM Discussion
    Last Post: 02-18-2019, 05:31 AM
  5. Help with Novusun NVEM USB control card
    By morg769 in forum Controller Cards
    Last Post: 11-13-2018, 11:19 AM
