586,058 active members*
3,712 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Tool changer no basic position - DMU 50V
Results 1 to 5 of 5
    Feb 2008
    10
    Hello Everybody.
    I am getting the following error in our DMU 50V machine: Tool changer no basic position error 3 [plc]. The machine turns on; but I am not able to move or change to any mode.
    Any help on how to solve this issue will be highly appreciate it.
    Jhon.
    Sep 2006
    8
    I'm having the same problem on a DMC 63v, did you fix it? and if you did can you tell me how you got it fix.
    thank you.
    sam
    Feb 2008
    10
    Tool changer no basic position - DMU 50V - Solution
    I used the rescue function and that solved the problem.
    To activate it, at least in my machine do the following:
    PROGRAM EDIT
    MOD KEY
    789 -> ENTER
    HELP
    SELECT STEP ->
    CYCLE START
    Regards,
    Oct 2009
    56
    Help Please re tool change
    Quote Originally Posted by hiatec View Post
    PROGRAM EDIT
    MOD KEY
    789 -> ENTER
    HELP
    SELECT STEP ->
    CYCLE START
    Regards,
    Hi I have this problem but I can not execute the the operation with cycle start.
    I get error 49 enter help code number
    This problem arose due to low air during tool change and I rebooted
    Can anyone Help
    Oct 2009
    56
    Quote Originally Posted by Ozcad View Post
    Can anyone Help
    I solved this problem buy ringing Dmgmoriseiki support here in Australia they stepped me thru the process of getting in to help files. Great support even for secondhand 14 year old models
  1. Hoss 16 Tool Automatic Tool Changer
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-03-2011, 10:29 PM
  2. Replies: 8
    Last Post: 02-01-2010, 04:45 PM
  3. Replies: 1
    Last Post: 10-08-2009, 10:36 PM
  4. Replies: 9
    Last Post: 03-22-2008, 05:44 AM
  5. Tool Changer picks up wrong Tool?
    By KJ45 in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2008, 12:51 PM
