586,082 active members*
3,772 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > SprutCAM 7 Annoyance #1
Results 1 to 17 of 17
    Oct 2004
    159
    I'm modeling a Circlip slot cutter in SprutCAM 7, basically a cylindrical part oriented to the Z axis. The workpiece is a cylinder around the part. The toolpath generation runs fine.
    On the simulation screen, however, with Machining Result Visible enabled, it insists on using a box workpiece around the part. Nothing I've tried will make it use the cylindrical workpiece. Is anyone else seeing this?
    I've gone through all the options settings and don't see anything that would seem to cause this. What am I missing?
    Attached Files Attached Files
    Jul 2004
    81
    Yep, I've seen that too. If you define your workpiece at the machine level then it works correctly.
    Oct 2004
    159
    wvines, thanks for the tip.
    I've got things working normally again, though I'm not sure redefining the workpiece at the machine level was the actual solution. It didn't work the first time, or the second, or the tenth (I can be a dogged b*****d sometimes )
    Eventually, something clicked and the simulation started working normally. I suspect it was just some obscure variable in the program that got hung up and wasn't updating.
    Problems that go away by themselves have a way of coming back by themselves. We'll see.
    Oct 2004
    159
    OK, I've spent some more time on this, and I think the problem I reported originally is just the tip of a big ugly iceberg.
    The problem seems to be in the simulation part of Sprut. On some projects, I either get the wrong workpiece displayed or no workpiece at all. In some I cannot make the machining result visible. If I try to export the machining result as an STL file to use as the workpiece in a subsequent operation, all I get in the STL is a simple box-around-the-part primitive. In all cases, the modeling and machining screens appear to be working normally.
    I am also getting occasional crashes with access violation messages involving the SprutCAM kernel (sckernel.dll).
    Is anyone else seeing similar problems? Don't know yet if this is a program bug or a hardware problem. I'm running SprutCAM 7 on an HP XW9300 workstation under Windows 7 Pro 64-bit.
    Would appreciate hearing from others.
    Jul 2004
    81
    I'm running Windows 7 Home and SprutCAM 7 build 0.6 rev 32868 on a homebrew i7 based system.
    Right now, cross my fingers and knock on wood, SprutCAM 7 is running very predictably for me. Not everything works the way I want it to, but it's working predictably.
    BUT, I did see some of the same problems that you are seeing on one design. It was a simple part but the workpiece was all screwed up. And the toolpaths were rotated with the tool approaching along the Y axis even though it was a 3-axis milling machine. I deleted the project and started over and everything worked fine.
    Also, I've installed SprutCAM 7 build 0.6 rev 32868 from 3 different sources. The first time was from Sprut Technology UK. That download did some very strange things. The second time was from Sprut Russia. That download worked pretty well but had a couple of stability issues. The third time was from the Tormach upgrade CD and also installed the new dongle driver. That installation has been very good so far. They were all (supposedly) the same version.
    The only crashes that I've seen with the latest installation occurred when I was invoking the postprocessor generator through SprutCAM instead of starting it directly.
    Jul 2004
    81
    I just did a binary compare on all 3 installation files and they were all identical. So maybe the trick is to go through the install/uninstall cycle 3 times. Or maybe it was the new dongle driver? Hmmm.....
    Apr 2008
    59
    Just curious, are you having problems with new files or files that were originally created in a previous version of Sprut?
    111011 101101 101001
    Oct 2004
    159
    cairns,
    Right now, it looks like files created in the previous version (2007) of Sprut behave normally. I've only had the problem in new projects created under Sprut 7.
    The files appear to load normally. If I open in the Model screen, the part and workpiece appear very small and then zoom to fill the screen, then they both vanish, leaving a blank screen. After that, I can only see them both by enabling Geometry model visibility. I can see the part and job assignment by enabling their respective visibility icons. NOTHING I do will make just the workpiece or machining result visible.
    The toolpath calculation appears to run without errors, getting green checks on all operations. The simulation LOOKS like it runs; the tool moves in all the right places, but I can't make the workpiece or machining result appear. The simulation screen remains blank except for the moving tool. If I export the simulation result to an STL file, it's an empty 1KB file.
    I've tried reinstalling Sprut 7, and I've given carte blanche permissions to all Sprut files, but so far nothing has made any difference.
    If anyone has any ideas, I'd be thrilled to hear them.
    Apr 2008
    59
    I wonder if you are running into a limitation or issue with your video card. Are you using the latest drivers? I'd assume so since you're on Win7.
    Oct 2004
    159
    I think I've narrowed it down to a problem with Sprut's handling of STL files.
    I've been trying to export the machining result of a project to an STL file using both the "Export" and "Save" functions in Sprut 7, then importing those STL files as workpieces for subsequent operations in another project. It is NOT working. The saved export files does not capture the machined features from the simulation. Instead, it appears to be just a box-around-the-part primitive.
    Sprut saves its STL files in binary; I've tried converting them to ASCII and importing them into the second project. I tried converting the Sprut exported STL file to IGES, and the conversion aborted with errors.
    Has anyone else tried to work with STL files in Sprut? Is this function broken in Sprut 7?
    Mar 2008
    309
    dkaustin -
    This is not exactly what you described, but could be related. I figured I'd pass it along just in case.
    I have run into cases before with 2007 where the simulation quits working correctly after I have had the program open for a long time. When it does this, as I recall, the simulation is basically the original part plus the tool moving around doing nothing. The cure for me is to save everything and restart the program. Simulation works again after reopening the file.
    By the way, I have imported STL files in the past, but primarily use IGES. I have not upgraded to 7 yet.
    You should be able to find many examples of STL files on the web. It might be worth a minute to find one or two and try them just to make sure it is not an incompatibility with your CAD program.
    Regards,
    - Just Gary
    Oct 2004
    159
    The STL files that Sprut creates check out OK in a 3rd-party STL viewer. Sprut's ability to import those same files, however, seems to be shaky. Sometimes it will work, other times not.
    I also think Sprut just plain does not like to be told what to use for a workpiece.
    It would have been a timesaver to be able to export the simulation results, but it doesn't look like it's going to happen. Time to find a workaround and move on.
    Jul 2004
    595
    I experienced a similar problem with the work piece in the simulation mode... I haven’t done much programming to this point with 7 but will in the near future and report back.
    I do have one question for you guys. In my quest to try and make my mill a vertical lathe and use Sprutcam to program it... I took Just Gary's advice and tried to use the ZX version of the lathe machine in sprutcam 7. When doing so, the work piece is oriented in the XY orientation. Same as when I choose Lathe XY. Nothing changes and I dont see a way to make it work.
    Anyone have any suggestions or tips... or maybe willing to see if you get the proper orientation between the two modes? If you still have 2007 installed I would appreciate if you could check that as well if at all possible.(I dont)
    David
    Oct 2004
    159
    For any who may not follow the forum at sprutcam.com, the answer was to disable the 3D Turbo simulation mode.
    This mode is enabled by default in my installation of Sprut, and I never had any reason to look at it before.
    Mar 2008
    309
    dkaustin -
    I'm glad you got it figured out. These things have a way of making you crazy. Thanks for posting the solution.
    David Bord -
    The display is rotated in SprutCAM when you use ZX mode, but post the toolpath and run it on your mill. You will see that it truly is ZX. I'm pretty sure that the reason is that it is all lathe work to SprutCAM, and the only difference is which axis to post as which in the final toolpath. It does all of the calculations in its own internal machining code, then translates it to your machine's G-Code during the posting process.
    Be sure to hold the tool the proper way when you decide to cut the part...
    Regards,
    - Just Gary
    Jul 2004
    595
    Thanks Gary.... Dave over on the Sprutcam forum said to enable Machine Visibility and that solved it for me. I believe your tools need to be mounted to the left of the spindle and pointed right?
    Hey another question for you if you dont mind! Do you use Mach3Turn? Did you have to do any configuring, or will the common Tormach install/settings work in Mach3? Any guidance is greatly appreciated!
    David
    Mar 2008
    309
    David -
    It's been a while, but I think you want the tool to the right (+X) of the spindle, pointed left, with the cutting edge facing away from you. To check it, program a very simple part (like a cylinder) and air cut it. If you set the speed override down to about 20% or so, you can watch it run and compare it to the motion you see in the simulation. Then you can decide which side the tool should be on to cut the program.
    Also, remember that you'll want to center the tool cutting edge at Y=0. You can use a straightedge gently pinched between the tool and the workpiece (as mentioned in the Tormach User's Guide under 4th axis work). When you touch off X, ithe value will probably equal the radius of the workpiece. Keep the speed override set low and stay near the space bar or E-Stop until you develop a feel for what is happening.
    No special configuration or anything. Just program it and run it on your mill, then post pictures!
    Regards,
    - Just Gary
  1. SprutCam
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 09-10-2009, 08:24 PM
  2. SprutCAM
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 06-30-2009, 11:45 PM
  3. SprutCam ver 5.53
    By RTP_Burnsville in forum SprutCAM
    Last Post: 06-12-2009, 12:47 PM
  4. SprutCam Ver 5.52
    Last Post: 06-03-2009, 10:59 PM
  5. Milltronics Error 450 E-stop annoyance
    By M_Controls in forum Milltronics
    Last Post: 09-20-2007, 03:14 PM
