586,115 active members*
3,453 visitors online*
Results 1 to 8 of 8
    Sep 2008
    9
    Agie sinker pump
    Where do you get parts for the Agie sinker 1986 I need a pump or repair parts.
    Jun 2005
    32
    why dont you replace it by any other pump running on the same supply
    Sep 2008
    9
    I thought it had to be a special pump that would pump the oil, grit, junk the filters didn't catch. any recommendations? Thanks
    Mar 2004
    1543
    Sep 2008
    9
    Thanks, I'll check it out. I searched online and didn't find this site. Thanks again
    Jun 2005
    32
    Quote Originally Posted by wtm5863743 View Post
    The grit will be minimal with the wire cut machine. The regular pumps used for slurry handling if not costly you can go for it. Otherwise a regular centrifugal pump giving required pressure & delivery is supposed to work. Any way they do work in murky water. Do not go for hi tech things unless called for in this case, as this is not going to damage your equipment. I think so.
    Sep 2008
    9
    This is for a sinker, not wire. The pump has no info on it.
    does anyone know GPM the pump should be?
    Jun 2005
    32
    dear sir,
    please check the voltages supplied to the motor, this you can check by a multimeter with wires disconnected from the motor & switching the supply to motor ON. and use any centrigugal pump with similar dimension & voltages. it should work.
  1. AGIE 100 wire
    By wtm5863743 in forum EDM Discussion General Topics
    Last Post: 09-07-2010, 01:20 PM
  2. Need help on Agie Puls 60 L2 EDM machine
    By Alfauser in forum Waterjet General Topics
    Last Post: 03-21-2010, 05:07 AM
  3. Agie-Charmille Cut 20 with FeatureCAM
    By lostinthe202 in forum EDM Discussion General Topics
    Last Post: 09-29-2009, 06:12 PM
  4. NX5 Postprocessor for an Agie
    By mirror86 in forum Uncategorised CAM Discussion
    Last Post: 07-03-2008, 01:04 PM
  5. Agie ETM 110 EDM
    By Fudd in forum Waterjet General Topics
    Last Post: 03-14-2006, 07:24 PM
