586,070 active members*
3,543 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Incremental vs Absoloute
    218
    How does one go about setting mastercam x4 to output absoloute rather than incremental gcodes ?
    I'm using mach3 for a cnc controller and I'm having to go into the config settings and run it in incremental mode in order to load the files mastercam is ouputting. If possible i'd prefer to keep mach3 in absoloute mode and get mastercam to output absoloute coordinates. Please could someone tell me how to do this.
    Cheers
    Dom
    http://www.ukrobotics.com/projects
    Feb 2006
    992
    Check your MISC parameter and tool parameter and check absolute option, I suspect it's increment, and try post again..... if output increment and I think you post is set to be increment.
    The best way to learn is trial error.
    218
    Where are these misc parameters and tool parameters you speak of ? I'm not overly familiar with the mastercam interface.
    Dom
  1. Incremental drill pgm.
    By Janos in forum Haas Mills
    Last Post: 01-25-2010, 01:30 PM
  2. Incremental tapping in MDI on a TL-2
    By Geof in forum Haas Lathes
    Last Post: 10-08-2008, 09:00 PM
  3. Switch to Incremental
    By moldmker in forum BobCad-Cam
    Last Post: 10-06-2007, 03:43 PM
  4. Absolute or Incremental
    By mikede in forum Haas Mills
    Last Post: 02-04-2007, 12:02 AM
  5. benefits of incremental?
    By paelscrit in forum G-Code Programing
    Last Post: 01-28-2006, 04:27 AM
