586,375 active members*
3,395 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > Matsuura Mill With yasnac controll, overload in x axis on rapid.
    Jan 2009
    245
    I have a matsuura Mill, 710 machine. Y and Z will rapid fine, using a G28 code, but when I go G28 X0, it will move about two inches then error our with x servo overload. Now I can move the x axis fine, but when I try to go to handle mode, and go fast, it will error out as well. There is no knob to turn down the rapid speed, or if there was, I would just go to like 50% rapid, and run it that way. Is there any suggestions? Is there a way to install a rapid traverse rate switch? What should I look for, as far as the X axis servo motor?
    Jan 2009
    245
    Basilcy, if there was a way to turn down the rapid on the controll board for the x axis, that would be the simplist, so it would not move so fast. Any Ideas?
    Jan 2009
    245
    Ok, Figured it out, and figured I would post so the archives have the info. There is a blue Potentiameter at the very upper left hand corner of the X axis servo controll board. I turned it about 10 degrees to the right, and it fixed the problem. I think that POT is actually the load alarm circut, and I told it to allow a bit more load. The table was completly free by the way.
  1. yasnac mx1 on matsuura programming help needed
    By Brian FRF in forum G-Code Programing
    Last Post: 07-29-2015, 03:09 AM
  2. YASNAC LX-3 on METHODS Slant 50 Rapid Traverse issue!
    By ballchain in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-06-2012, 10:01 AM
  3. yasnac mx1 on matsuura programming help needed
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 08-04-2009, 07:57 PM
  4. Matssura....Yasnac MX-1 controll
    By Canuhelpme in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2009, 09:03 PM
  5. Yasnac/Matsuura parameter specifying Z? HELP!!
    By arobustus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-16-2008, 09:28 PM
